can i fit 31's on a stock tracker.....
  • 7 Replies
  • 1809 Views
Offline westvilleguy
  • 53
« on: January 06, 2007, 02:04:57 PM »
just wondering if i can fit 31's on a stock 89 tracker with a lot of cutting and no lift the body is done already removed the front fenders that were toast and they wont be going back on cut alot of the rear quarters out doesnt matter how it looks just gonna be for the woods once i get the frame fixed runs and works great so would rather get some use out of it rather than have it sit in the yard till i need parts of it
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline TysonS
  • 383
  • www.funinbc.com
Re: can i fit 31's on a stock tracker.....
« Reply #1 on: January 06, 2007, 07:03:09 PM »
yes, they will fit
« Reply #2 on: January 07, 2007, 08:40:56 PM »
ya they fit with rubbing ,but mine was for fun and i did not care. run a year like that. rubbed all the paint off the firewall ,but riding in ky was priceless
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #3 on: January 12, 2007, 03:37:10 PM »
They will fit WITHOUT rubbing if you beat the firewall back with a BFH....
and trim the crap out of the rest..
no problem... except maybe rubbing on the frame if you are using stock wheels....
Offline costa 05
  • 206
« Reply #4 on: January 13, 2007, 12:11:25 PM »
Of course they will. Can you say saws all >:D
when in doubt gas it!!
Offline explosivo
  • 3157
« Reply #5 on: January 14, 2007, 01:00:23 AM »
I had a set of 33's on my Tracker with a body lift, lots of fender trimming and some beating of the firewall. They rubbed on the frame (because I was running 4" backspaced rims), but with fairly offset wheels and some fender trimming, you should be able to take care of the body clearance issues pretty easily.
omghi2.us[/url]
Offline 89tintop
  • 356
« Reply #6 on: January 14, 2007, 10:02:19 AM »
just mount your wheels reverse.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline Bogger4life
  • 11
« Reply #7 on: January 15, 2007, 09:34:49 AM »
I run 32" AT's on no lift currently.... on aftermarket wheels though... at full lock it runs the frame a bit and when fully flexed they rub... i would use a 2" spacer if i was to do it again
89 Tracker Rollin Around On 35" Mickey T Baja Claws
