Rebuilt the knuckles (Sammy's Balls) this weekend
  • 0 Replies
  • 810 Views
Offline RShrimp
  • 28
« on: January 15, 2007, 02:13:30 PM »
Had a grease leak on the left front so desided to tear into it this weekend.
I found the left front inner wheel bearing was bad and both upper king pin bearings were also toast.
I installed grease fittings on the rear of the steering knuckles while I had it apart and that seems like it is gonna work out great.
I bought all of the parts from samuraiparts dot com and they had everything in stock, shipped it quick, and were also the least expencive for a total price.
It is not offen that you get all 3 (cheaper , faster , better) but they have been great.
While I was in there I decided to do the brakes, replace all of the bearings and seals.
It is really a pretty easy job. I spent more time at the parts washer than in assemby disassembly.
The one major tip I have is to make sure you slip the green seal over the ball before you install the new king pin bearing races.
I also found that putting it in boiling water for a couple minutes made it stretch pretty easy.
88.5 Samurai with spring over and 31,s
Americas Oil problem is simple. We just can't seem to check our oil.
The oil is in Texas and Alaska .... The DIP STICKS are in Washington!
