RRO 2.5" lift and camber bolts
  • 18 Replies
  • 3385 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: RRO 2.5" lift and camber bolts
« Reply #15 on: October 18, 2006, 12:30:11 PM »
Actually, I DID. Both my rigs have camber bolts! ;)
LOL!
Offline Brushpopper
  • 14
« Reply #16 on: October 18, 2006, 12:55:06 PM »
Good had me worried for min.
firefighters leave'em wet
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #17 on: October 18, 2006, 02:33:25 PM »
Y would you do all that to the strut when camber bolts are $15.99 a set from O'reilly Auto Parts. Or will I have to add this on top of camber bolts.
I'm in the lost part of Canada.... the only camber bolts I could find were Moog, and they were $39.99 each, so that's close the $100 with taxes, and I heard the cheap ebay camber bolts don't hold up and can break.  As well as seeing this strut mod online, I've seen new aftermarket struts out of the box with this same slot adjustment, so I figured it must be safe. Once everything is set, I'm going to weld a washer to the strut on each side.
« Reply #18 on: October 18, 2006, 09:30:50 PM »
WOW. I found mine at a local tire shop (Les Schwab) for 20 for the pair.
