K10A Gearbox into LJ80
  • 1 Replies
  • 1735 Views
Offline Warent
« on: January 25, 2017, 08:14:32 PM »
Am wanting to replace the F10A in my LJ80 with a K10A Turbo running an Auto gearbox. Can anyone recommend a suitable box for the job. Will a gearbox from a Cappuccino or Carry do the job?
Re: K10A Gearbox into LJ80
« Reply #1 on: January 26, 2017, 11:58:14 AM »
The LJ still has the divorced transfer case, so you should be able to use any automatic transmission that has a rear output.  I believe the Carry has the same drive train and the SJ-410, so that would be a good swap.
You might want to double check though, it's been a while since I looked at doing a 1.0L Turbo swap.
