5.12's, 3 speed auto..... 33's
  • 12 Replies
  • 2918 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« on: June 18, 2007, 01:05:16 PM »
So I have a 94 tracker 3 speed auto that I recently tossed 5.12's into upgrading it from 4.62's.  I currently run 31x10.5's but was thinking of going to 33x9.5's
anyone run 33's with auto? how is it....  I assume with the 5.12's will be fine.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: 5.12's, 3 speed auto..... 33's
« Reply #1 on: June 18, 2007, 06:25:30 PM »
I run a similar setup and all I can say is don't plan on passing any VW's onroad and unless you do T-case gears offroad will suffer also
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline john1974
  • 617
    • Zuknation
« Reply #2 on: June 18, 2007, 06:42:43 PM »
hmmm I am not sure about that with the 5.12's and 31x10.5's I am running 75MPH easy... and I have gear left to run.  I would think a 33x9.5 will not be much more LBs on the tires, and with the 5.12's I should have enough gear for highway driving.
Just seems this way to me know that I have 5.12's with my 31x10.5s
Offline WorkInProgress91
  • 31 gets it done
« Reply #3 on: June 19, 2007, 07:29:33 AM »
Try it! thats the same setup that i'd like to run.  are you looking at the tsl's?
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
Offline john1974
  • 617
    • Zuknation
« Reply #4 on: June 19, 2007, 10:39:06 AM »
TSL are my fav.... right now im not looking just thinking about it.  I still have otherthings to do to my rig before then anyhow.
« Reply #5 on: June 19, 2007, 11:08:22 AM »
Its about  6% difference in rolling diameter so you will lose 6% of your power/torque at the rear wheels. I forget if yours is a 16V or not. Biker's truck i would assume is an 8V as its a 91 (according to his sig). The 16V has a lot more power to spare.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #6 on: June 19, 2007, 05:21:03 PM »
I'd like to know the results if you go that way as well, considering it myself as I'm running the 31x10.5 with an 8V.
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #7 on: June 19, 2007, 09:38:28 PM »
i don't think your front end driveline is going to like to, i blow up cv's and diffs with 31's in the mud...
Offline slade11_98
  • 22
  • 97 Geo Tracker with performance 1.6 16 valve.
« Reply #8 on: June 20, 2007, 08:48:19 AM »
I found this little tool. It might help you on your gearing.
http://www.bfgoodrichtires.com/bfgapp/popups/demos/demos_offroad_0.jsp
Offline bandit86
  • 1641
  • elv8rguy
« Reply #9 on: June 23, 2007, 09:30:52 AM »
I ran 33x12.5 on a stock 8v with stock gears.  Instead of 5th I used 4th on the highway, just like going from 512 to 589 in the axles
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: June 24, 2007, 02:43:24 PM »
I wouldn't but that's just me.  Drove around on 31's and 4.30's too long.  Like the power I got back with the 5.12's.
16v, 3 speed, and 5.12's on 31's.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #11 on: June 24, 2007, 06:13:08 PM »
I ran 33 x 9.5s with 5.125's (stock gearing) in a 4 spd auto lwb 16v and it was drivable but not great and I could get up to speed on freeways etc. but I pretty much gave away the O/D part so top was 1:1 in 3rd just like a 3 spd auto. Some engine mods helped performance in the end but gearing is really the answer here. Now if Calmini gets those 5.83's back on the market soon (supposedly back in production now) you will have a great solution.
« Reply #12 on: July 07, 2007, 02:12:13 PM »
dead on gear change to 5.62 would put u at stock ratio in theory, but bigger tires
sap power just because
