Sidekick won't start !
  • 983 Views
Offline hman1991
  • 53
« on: January 13, 2007, 06:00:49 PM »
i just got a automatic 92 4 dr 16v sidekick today. now went to start it and wouldn't. i kept messing with it and got it to turn over and fire 2 times. then after that nothing. also i donot hear a relay or anything when i go to crank it. the relay comes on when u turn key to on and everything else works (radio, windows, heater, etc) also when key is on and i apply brake the shifter does not release but brake lights work. anyone help me here?
Offline Uncivilized
  • 1469
    • Car Domain
Re: Sidekick won't start !
« Reply #1 on: January 14, 2007, 08:48:31 AM »
Try another Known good ECM, maybe a friend has one you can use, or if you know someone at a salvage yard, you could ask to borrow one for testing.
Offline 89tintop
  • 356
« Reply #2 on: January 14, 2007, 09:59:43 AM »
also at the bottom of your shifter there should be a button that you can pull out and that will allow you to take it out of park without touching the brake pedal.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
