Lost gears?
  • 1178 Views
Offline lacrosse10604
  • 50
Lost gears?
« on: July 30, 2006, 08:29:14 PM »
hi. I did the homemade 3" body lift, front strut mount flip and crown vic shocks. I extended the shifters. Now my shifter won't go into 1st, 3rd, and 5th gears. I can get into 2nd, 4th, and reverse.
Any suggestions?
Searching for a donor for my diesel build.
Offline kirknd4spd
  • 333
Re: Lost gears?
« Reply #1 on: July 30, 2006, 08:50:07 PM »
make sure the shifter isnt hitting the body inside the transmission tunnel.
89 Sidekick - 2 door soft top, 1.6, auto, 4x4, 3" suspension lift, 31x10.50's on 15x8 Mickey Thompsons, long tube header
Offline da_tub
  • 307
Re: Lost gears?
« Reply #2 on: July 30, 2006, 08:50:18 PM »
wasthe shifter in neutral when u took it out?
91 four door ,and some stuff
  • 50
Re: Lost gears?
« Reply #3 on: July 30, 2006, 10:01:31 PM »
No, its not hitting the body.
It probably was in neutral when I took it out.....but then again I may have moved it into a gear to as I struggled to depress the spring....
« Last Edit: July 31, 2006, 05:50:48 AM by lacrosse10604 »
