Lower range for 90 Track/kick?
  • 1514 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: December 18, 2004, 02:20:30 PM »
I am interested in a lower range T-case setup for my Tracker, but everything I've seen online is for 91 or newer. Why is this? Is the 90 Tracker's Tcase that much different? Does anyone know of any setups that would work on my 90 Tracker?
Re: Lower range for 90 Track/kick?
« Reply #1 on: December 18, 2004, 02:26:19 PM »
You just need to get a newer
T-case, might as well do the
gear swap while the T-case is
on the ground, then it's a quick
swap, should only take an hour
or two, Nike says he can swap
out a T-case in 15-30 Min  :o
Offline Digger
  • 1991
« Reply #2 on: December 18, 2004, 02:33:45 PM »
So I can just pick up a 91 or newer Tcase, swap in the gear set and it will bolt right into my Tracker? Are the Tcases different for autos and manuals or are they all the same?
« Reply #3 on: December 18, 2004, 02:46:41 PM »
Same as far as I know, but that's about it
Hawks would be a good place to look, or
your favorite wreckers
« Reply #4 on: December 18, 2004, 11:26:50 PM »
The 89 and 90 t-case gears were not all the same. There were some with different sizes. So it might work and it might not :-/ When I first got my set form GRP they would not fit. But after a quick call to AU at 4:00am local time, Greg let me know that there were some differences and had me the correct set on the way. After 90 I think they are all the same.
