manual to power steering
  • 1583 Views
Offline museboy07
  • 641
« on: January 25, 2007, 07:37:29 PM »
can i put power steering in my 94 track thats got manual steering...if so what will i need?
Offline wezzlegod
  • 227
  • under construction crowler
Re: manual to power steering
« Reply #1 on: January 25, 2007, 07:53:34 PM »
yup the stering box is exactly the same exept for the hidro lines.
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline Eden1
  • 73
« Reply #2 on: January 25, 2007, 10:13:36 PM »
I just put power steering in my 92 tracker the other day and the gear box is not the same it is larger.The pump and resevoir are easy hookups.Also make sure you get the intermediate shaft from the unit as u will need the shorter shaft becouse of the diffrence in size of the gearbox.Good luck and have fun.
« Reply #3 on: January 26, 2007, 08:12:45 AM »
It is a complete bolt on.  You need the steering box with pitman arm, the pump with pulley, the steering shaft, the resevior, the lines, and a longer belt.
Offline cablesmurf
  • 123
  • Calgary Alberta Canada
« Reply #4 on: January 26, 2007, 09:47:56 AM »
Anyone seen a write up anywhere?
Sold the Tracker, done with wheelin'...
Compliments of your friendly neighborhood cablesmurf
Check out my Powerlifting video...  http://whiteknight.scriptman
