Mile Marker Winches
  • 15 Replies
  • 3996 Views
Offline ADavis
  • 209
    • Aaron's Webpage
Mile Marker Winches
« on: October 03, 2006, 01:21:07 PM »
Hey folks,
I was wondering what you guys thought of the Mile Marker winches.  I was thinking of getting the 6,000 lbs. winch.  It is a lot cheaper than the warn, so I'm wondering if I should just pony up the money for the warn winch or go with the Mile Marker.
Thanks!
Aaron
Re: Mile Marker Winches
« Reply #1 on: October 03, 2006, 02:12:37 PM »
If your going to go with the Mile Marker, I would go ahead and get the 8000lb.  It's only 12 pounds more and 5" wider.  And they seem to cost about the same and the 8000 is a little bit faster with a load on it.
I had the Mile Marker 8000 on my Jeep when it first came out, and it worked fine.  Some people have had problems with the plastic switch breaking off, but it seems to be pretty rare.  It is not a fast winch though, and if I was planning on using it a lot I would probably go with a Warn just for the extra speed.
On a side note, dual batteries work great for winching.  That way you don't need a heavy duty altenator to keep the winching up.   ;D
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: October 03, 2006, 04:57:09 PM »
You might as well go to costco/harborfreight/sams to buy a winch instead as they're all just as "good" as each other.  (not that i think they're good)
1993 4-door Sidekick
4.24:1 t-case
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #3 on: October 04, 2006, 05:43:16 AM »
Right, it's the same winch, made by the same folks in China, they aren't great, but I have heard that they hold up fine, and do a fine job on these little trucks
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #4 on: October 04, 2006, 06:37:56 AM »
Silver's been running a milemarker 3000 and the Goblin runs a 6000 milemarker and both work fine and neither has given me any trouble. The 6000 has pulled the goblin through some pretty deep sticky mud, too and it worked great without any overheating...
Offline SKAsammy
  • 79
  • 1991 samurai
« Reply #5 on: October 04, 2006, 11:49:36 AM »
i run the harbor frieght 8000, which is the same as the milemarker 8000 and its  more than enough for a sammy or trak
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Offline 88Sammy
  • 68
    • JDM parts
« Reply #6 on: October 04, 2006, 12:49:56 PM »
Costo has the Mile Marker 8000 for $329.99
http://www.costco.com/Browse/Product.aspx?Prodid=11107204&search=winch&Sp=S&Mo=6&cm_re=1-_-Top_Left_Nav-_-Top_search&Nr=P_CatalogName:BC&Ns=P_Price|1||P_SignDesc1&N=0&whse=&Dx=mode+matchallpartial&Ntk=All&Dr=P_CatalogName:BC&Ne=4000000&D=winch&Ntt=winch&No=0&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
« Last Edit: October 04, 2006, 12:51:41 PM by 88Sammy »
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #7 on: October 04, 2006, 11:49:54 PM »
I currently have 2 trail rigs; one with a Warn M8000, and the other with a milemarker SE9500.  No doubt I like the Warn better; it's much quieter (the milemarker makes all sorts of racket under any kind of load), faster (probably twice as fast as the MM), and has an overall better fit and finish.  With that being said, for a winch that will be used just occasionally, the Milemarker isn't a bad deal.  It still pulls you out of a ditch or through a muckhole just like the warn does (even though it does it slower, louder, and without as much style).  And, you can't argue with the price difference.  So....if you have the $$, go for the Warn.  It is a better machine.  If you don't, go for the Milearker.  It will work fine.
« Reply #8 on: October 05, 2006, 01:07:42 AM »
Or check around in the ads of your local papers or Craigslist.
I bought another Warn 8000lb for 300 bucks (3).
Bought that one for my Lil Bro.
Online RJkick
  • 632
« Reply #9 on: October 05, 2006, 12:01:52 PM »
What kind of batteries and alternators do you all run?
Is the stock battery and alternator fine or is there a sweet/optimal setup
« Reply #10 on: October 05, 2006, 01:18:54 PM »
I run dual 6v in series with a stock altenator.  :)
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #11 on: October 05, 2006, 03:17:17 PM »
I'm running a powermaster 140A GM alternator, and dual exide orbitals.  It works great.  Runs everything I could ever want, no problems.
« Last Edit: October 06, 2006, 10:43:16 PM by sewerzuk »
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #12 on: October 06, 2006, 06:11:15 AM »
Anyone running a single battary hook-up?  It would be interesting to see how well it works.  Thanks
Aaron
Offline Digger
  • 1991
« Reply #13 on: October 06, 2006, 06:45:20 AM »
I'm running the stock alternator and a single Optima Yellow top battery. Works fine for the occasional use I put it through...
« Reply #14 on: October 06, 2006, 10:36:12 PM »
Red top optima. works good.
Haven't done anything major with it tho.
