Samurai and sidekick gearing
  • 18 Replies
  • 5639 Views
Offline Element
  • 1902
  • LillyKicker
Re: Samurai and sidekick gearing
« Reply #15 on: April 29, 2008, 06:48:03 PM »
Lostsamurai picked one up early on... Don't think ir is on the website, but you may be able to call and ask for one...
I will look for a pic...
It's no big deal.  It's just that I have heard about this "piece" on several different forums, but have yet to see any pics of it.
It's like the pot of gold at the end of the rainbow...
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
Offline idaholwb
  • 772
« Reply #16 on: April 29, 2008, 08:00:16 PM »
 I've had one of those pieces from Brent. Pretty simple. It allows use of the tailhousing bushing and output seal from the Sami trans to be used in the back of the Trackick/Vitara maual or automatic. It's really cool too. He developed it for his Sami pickup that has a GV 2.5 V6.
 Cool score on the 1.3 Kick! Suzuki offered that exact model simply as a very cheap 4X4 to get people in the door, the dealers normally upsold to the 1.6 version. That is why not many exist. They were built all through the '89 model year.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Hillbillydave
  • 213
« Reply #17 on: April 30, 2008, 06:42:17 PM »
Does this piece fit a 2wd or 4wd kick tranny? If it fits the 4wd, do you eliminate the kick tcase or can you run out of the kick case into the sammy case? You would have some serious gear options then.
Thanks for all the info, guys!
'89 sidekick 1.3L 3" blue suspension parts, custom strut extensions 31x10.5 Mud Trac's on 10" rims rear fenders trimmed, lincoln locked rear, Rochester Carb on custom adapter
93 Sammy project, SPOA with 34's, 5.12's, welded, in the works
« Reply #18 on: May 01, 2008, 05:08:54 PM »
Hillbillydave,
I found this gearing site.
Works pretty cool when you plug-in any gear por tire changes.
http://www.lepayne.com/gears.html
