Will my Digger 1.5" spacer lift let me run 30's?
  • 7 Replies
  • 1460 Views
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« on: July 03, 2006, 05:39:17 PM »
I have finally given in and want to install the 1.5" Digger spacer lift on the Tracker 4-door so I don't have to drive it bone-stock at the Melt.
However...
If it won't lift the truck enough to run the 30" BFG A/Ts, I won't do it...  I was going to do the mod at the campground and if it won't work, I might as well leave the tires at home (Kansas City).  It'll look "festive" on stock tires, but I'll at least get some body damage protection from the lift...
So, can I run my 30's after this lift? ???
Leaving in 35 hours...
Ack
Offline ddevil
  • 155
Re: Will my Digger 1.5" spacer lift let me run 30's?
« Reply #1 on: July 03, 2006, 06:45:53 PM »
i'd say yes.  at least with my recent 1.5" spacer lift on my two door i'm positive i can put 30's under there now.  i'm going to post some pics here shortly.
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline da_tub
  • 307
« Reply #2 on: July 03, 2006, 09:19:58 PM »
i'llsay yes .. i've got them in my four door,, should get two or two an a halfs for the back. just to give it that little bit of rake.. mine's a little nose high with just the 1.5's on all corners.. you might want to do them bofor you go though. cuz you'll need a wheel alignment  quite badly.. camber bolts and reset the tow...
91 four door ,and some stuff
Offline bzzr2
  • 1011
« Reply #3 on: July 04, 2006, 05:35:37 AM »
they 'should' fit ok, they will likely rub the frame when turning but not bad with AT grips.  i have the same setup on my 2003 2dr with no problems at all.
09 taco reg cab short box 4x4
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: July 04, 2006, 06:53:24 AM »
235/75R15's fit stock so 30x9.5R15's will fit stock as well.  They'll rub the frame a teensy bit more but with that lift that would still be the only "rubbage."
Offline ack
  • 1659
    • Ack's FAQ
« Reply #5 on: July 04, 2006, 07:02:29 AM »
Excellent!
I'll be running them on the Bronco Wagonwheels off my Samurai.
At least I'll be able to run the dunes and the mild trails...
Thanks!
Ack
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: July 04, 2006, 09:16:45 AM »
A friend of mine has 30x9.5's on his stock sidekick, using stock rims, minimal rub.
I have 1.75" of lift using spacers, I have 30x9.5's on mine using 15x7" wheels, mine rubbed on the pinch weld a little bit, and the inner, lower corner of the fender, but I fixed that with an angle grinder and a hammer.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #7 on: July 04, 2006, 04:24:25 PM »
Hey Ack, good luck with the install and get some before and after pics, we love pics! LOL! 8)
