My live axle project so far
  • 8 Replies
  • 2964 Views
Offline mbmarkyb
  • 461
    • UK Vitara
« on: August 07, 2005, 03:27:08 PM »
After lots of thinking moaning and head scratching I decided I have had enough of camber problems -resulting in bearings going etc etc.
I decided to go live axle on coils using  a sammy axle
Here is where i am at , im doing a write up on my website here http://www.markyb.co.uk/live_axle.htm
Here is a couple of pics but the rest are on the link above let me know your thoughts.
Markyb (UK)
UK Vitara JLX SE
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: My live axle project so far
« Reply #1 on: August 07, 2005, 03:46:38 PM »
looking good markyb. just wondering if you are going to brace/gusset the axle tubes on the sammy diff?
and i just wish i could have those blue bits that you've taken off.
let us know how it all goes.
GRVIT
« Reply #2 on: August 07, 2005, 11:37:31 PM »
The coil springs I see are stock sidekick fronts ?
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: August 08, 2005, 12:58:22 AM »
Bracing up the axle is in te plan i will get it up and running and then have a go, im not the best at makig things like that so it might come later.
Yeah those springs are LWB ones as they were going on top of the axle under chassis i didnt need long ones it is sitting nice at present with a few changes to be made this weekend
Markyb (UK)
UK Vitara JLX SE
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #4 on: August 08, 2005, 01:18:46 AM »
Looking good so far mark.
Will be an ace truck when its finished.
Will have to have a twist off to see weather my vit on hilux axles and leaves is more flexy than your coil set up.
he he he
GRVIT
« Reply #5 on: August 08, 2005, 02:28:15 AM »
I used those first,but I changed them cause they are designed to be used with IFS set up.They must be aprox 400 Lbs ,too stiff,they wont give you much flex.For a solid  I believe you d better use 200-220 Lbs.Are you going to use a panhard on the front?
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #6 on: August 08, 2005, 06:39:47 AM »
Tony, we will in deed have to have a felx off.  I think it will take me a few months to get it tricked out to full flex , im concentrating on getting it working right but it should flex.
grvit
I need to get my truck weighed but with the external cage winch etc it must weigh in nearly 2 ton as my old calmini springs used to touch.  I agree 400lbs would be too much for a fairly standard truck but with the extra weight im hoping they will be good,
without the shocks installed i can rock from side to side falirly easily at the moment ,   I will see once its up and running and change the springs if needbe once i get it out on a test run. probably going to dump the rear springs too as they are sagging badly.
Markyb (UK)
UK Vitara JLX SE
Offline zaggy
  • 1134
« Reply #7 on: August 08, 2005, 07:05:42 AM »
Good work Marky
     Nice pics and descriptions, my turn to learn some stuff! Excellent!
Zag
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #8 on: August 08, 2005, 07:56:29 AM »
cheers mate, i will probably up date the descriptions some more . lots of head scrating sessions that i havent put in :-)
Markyb (UK)
UK Vitara JLX SE
