My new cold air intake....
  • 30 Replies
  • 5088 Views
Offline wolf66
  • 193
« on: June 04, 2006, 02:57:25 PM »
........so I didn't like the current setup i had,  the filter sat right over the header and drew in hot engine compartment air which is bad for performance and the filter was going to suck in water in deep water crossings.....
« Last Edit: June 04, 2006, 03:00:52 PM by wolf66 »
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline wolf66
  • 193
Re: My new cold air intake....
« Reply #1 on: June 04, 2006, 02:58:05 PM »
........so i been thinking for awhile how to get the cone filter outside for cold air but close as possible because the longer straw (hose) you suck through the harder it is...
so i got out the trusty ole sawzall and made me a side hole like this:
Offline wolf66
  • 193
« Reply #2 on: June 04, 2006, 02:58:33 PM »
...then I routed the air hose this a way:
(if you notice, you see I put the stock heat shield back on top of my DT header also)
Offline wolf66
  • 193
« Reply #3 on: June 04, 2006, 02:59:10 PM »
...and here you go, a partially recessed outside cone filter, i just need to extend the rain guard back a inch or three now... and it will rotate up for snorkel use...
Offline Praise Him
  • 256
« Reply #4 on: June 04, 2006, 03:14:24 PM »
Hmm, i hope it doesnt rain were you live.or you go threw puddle or puddles, your gonna be Screwed.....
Looked better under the hood
sammy/toy axles/locked/geared/cased/36's
Offline wolf66
  • 193
« Reply #5 on: June 04, 2006, 03:18:52 PM »
well to me its what ever gives me a higher power-to-weight ratio looks better  ;D ...and sucking in hot air is not the way to go..
As to rain,  the inside of the wheelwell is sealed and once I extend the shield back about 3" it will be fine in the rain, and i have front fender flairs so no puddle splash either... 8)
« Last Edit: June 04, 2006, 03:20:38 PM by wolf66 »
Offline wolf66
  • 193
« Reply #6 on: June 04, 2006, 03:48:47 PM »
up will look like this:
("#1, stand by to raise snorkel..."  :o)
« Last Edit: June 04, 2006, 04:50:31 PM by wolf66 »
Offline track_this
  • 332
« Reply #7 on: June 06, 2006, 09:59:14 AM »
i like it way to go on the new idea ;) only down side might be when in "snorkel" position it might be pushed back if it were to come in to contact with something. you might try to incorporate a support rod that would brace it. anyway good job!
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
« Reply #8 on: June 06, 2006, 01:26:38 PM »
Well, it certainly looks cool.  :)
I would worry about ripping that entire setup off on a tree though.  Then again, I tend to have a lot of wear marks on the side of my roll cage.  ;D
Offline wolf66
  • 193
« Reply #9 on: June 06, 2006, 02:28:48 PM »
Yeah I'll have to watch that but since my X still has a shine i don't rub stuff if I can help it, and it sticks out about the same as my mirror and fender flares...plus being on the drivers side i can watch out for it...
« Reply #10 on: June 07, 2006, 11:15:34 AM »
Looks sweet. It's always good to see a clean job.
~J~
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
« Reply #11 on: June 12, 2006, 12:26:57 PM »
Ok so I have to ask since I missed it or noone else has....
What is the other chrome thing on the hood??
Toolman
Offline wolf66
  • 193
« Reply #12 on: June 12, 2006, 12:30:17 PM »
That was my original cold air intake inlet (it used to face fwd) but it was too low for water crossings..
Offline toolman21
  • 229
« Reply #13 on: June 12, 2006, 12:44:55 PM »
Ok, just curious if it was a gauge or something since I didn't see anything under hood that it would connect to.
Clean install though. :D
Toolman
Offline wolf66
  • 193
« Reply #14 on: June 12, 2006, 03:49:44 PM »
Well we have a tropical storm inbound here, been raining all day so i whipped up this:
