my tracker (snorkle pics)
tracker8wr
568
THE BIGGER THE BETTER
May 27, 2004, 12:27:12 PM »
here are the pics of my snorkle.
IMG]http://www.kielbassa.com/pictures/t4.JPG[/IMG]
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
http://www.geocities.com/race8thwonder01/
http://www.cardomain.com/memberpage/769479
explosivo
3157
I'm in the northern part of that one state.
Re: my tracker (snorkle pics)
May 27, 2004, 12:32:23 PM »
I like it... looks much neater routing it that way than ripping a hole in the side of the fender, which is what I did. I'll have to get pics of the finished deal sometime...
omghi2.us[/url]
Its a ZUKI thing. Doing more with less than less with more.
" -- HotRod
trackermad
150
May 27, 2004, 12:35:59 PM »
Oops what happened to your mirror? Ive been trying to think of wa way to put on a nice fold away myself. Anyone go suggestions?
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so." ~Bertrand Russell
1bigtracker
3409
F*** trail rated, try trail tested
Reply #3 on:
May 27, 2004, 12:42:08 PM »
i got my folding ones off a older s-10. they fit on vary nice but are a little big
stu
 ÂÂÂÂÂÂÂ
explosivo
3157
Reply #4 on:
May 27, 2004, 12:50:29 PM »
As soon as I'm done driving the Festiva for the summer, I'm swiping the mirrors off that... I think they'll fit the bill perfectly: Around the same size mounting area, small surface size, flexable connector dealie, etc.
omghi2.us[/url]
" -- HotRod
mperry
Reply #5 on:
May 27, 2004, 01:11:53 PM »
Pretty nice. Will you be trimming the pannel and putting it back?
tracker8wr
568
Reply #6 on:
May 27, 2004, 01:28:23 PM »
no the panal is welded in and it would take alot of fab work plus i built to off road.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
90Stomper
427
Reply #7 on:
May 27, 2004, 01:50:59 PM »
hmmmm i like
, gives me some ideas
what did you use for the pipe going up the window, what diameter, and what dia is the pcv pipe going under the hood? does it rub on the hood? what is that your using for the top? how are you going to incorperate an air filter, or are you? looks good
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
but its covered with lots of big 'S's on the inside
tracker8wr
568
Reply #8 on:
May 27, 2004, 03:18:21 PM »
it conects to my stock airbox and i have a k&n filter in it. it is all 2" PVC the top is from electical PVC it is made for the power lines coming into your house from the pole it is gray. there is also a new paint that is made for plastic it stays on really well.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
extremekickin
61
GO ZUKI OR GO HOME!!!
Reply #9 on:
May 27, 2004, 04:19:49 PM »
I used sammy mirrors on my zuki. looks good and tuck away nicely
1990 1.6L 8V kick,2.5" body and 2.5"sus lift,pro9000 ramsey winch. Full skids,30X9.5 mud kings,15X7steel wheels.Removable doors, Zuki Swift seats,Hi-lift,Steel rear bumper,Electric fan,K&N filter.
Digger
1991
1996 Suzuki X-90 4X4
Reply #10 on:
May 27, 2004, 04:30:05 PM »
Looks great, nice pics. Once the dummy panel is removed, did you have to modify anything else to clear the pipe?
About the swing-away mirrors, approx what year s-10 and do they fit the stock location on the door pillar? Please let me know! Thanks.
1bigtracker
3409
Reply #11 on:
May 27, 2004, 11:49:50 PM »
it was like an 80's style s-10 and you have to dill the holes for them on the door. mine do NOT have covors on them so if you want some to hide the base of the mirror then you will have to mod the s-10 ones.
stu
 ÂÂÂÂÂÂÂ
ProjectTwin
35
Reply #12 on:
May 28, 2004, 04:21:42 PM »
There are usually folding Track/Kick mirrors on ebay for 52 bucks each...
If it's worth building, it's worth
over-building!
mperry
Reply #13 on:
May 28, 2004, 05:23:04 PM »
Yep, or you can sometimes find the same price at your FLAPS. (Similar to these for about $50.)
http://bodymasterautoparts.com/SearchResult.aspx?&Vendor=257
