My Tracker.....Please vote....Remove stripes or not...
  • 46 Replies
  • 6504 Views
Offline hobgoblin
  • 224
« on: March 24, 2006, 12:28:21 PM »
Hello All,
Just thought I'd post a pic of mine,It has a 2" Sky body lift and 1.5" Sky spring spacers,Aftermarket 4x4 frt skid plate,Lock-right locker,Gas tank lift,95 style top and seats,custom frt bumper with 8000 lb winch,I have a DT header on the way,It has a cold air intake,MSD coil,Hurst shifter,Kenwood CD player,I'm sure there are other things I'm missing....It looks funny with the stock tires and wheels,but I'm going to get the motor 100% before the tires and wheels are bought. I'm going with Bart 15x8 with 3" BS and 31x11.50 Swamper LTB's I've got the rocksliders almost done,and making a custom rear bumper also. Might do a cage later this year....And I'm taking the stripes off the side soon....what's your guys thoughts on the stripes?
Later Tom K
Offline turbodrabbit
  • 89
  • I run emission equipment
Re: My Tracker.....Please vote....Remove stripes or not...
« Reply #1 on: March 24, 2006, 12:55:21 PM »
Take them off.
87 tintop...waiting for toy axles
'94 softop going diesel
'90 Samurai Softop stock
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #2 on: March 24, 2006, 01:07:07 PM »
Oh yeah... lose the vinyl... vinyl is for  wannabe ricers.. LOL..
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: March 24, 2006, 01:10:19 PM »
Gas tank lift with a 2" b/l? tell me more please. I want to do this mod but just havent had the time. Did you remove the white evap chamber on top of the tank or what?
     Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: March 24, 2006, 01:13:21 PM »
Oh yah, check out wy graffics at first I hated them but now they've grown on me.
  Kevin
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
« Reply #5 on: March 24, 2006, 01:26:33 PM »
I am ok with graphics,but should'nt those be on the bottom of the door?Mine are on the bottom
of the door i think they look ok.
« Last Edit: March 24, 2006, 01:28:17 PM by FNG »
Offline zukikick32
  • 6
« Reply #6 on: March 24, 2006, 01:28:06 PM »
rip em off ;D
Offline the_maplebar
  • 466
« Reply #7 on: March 24, 2006, 01:31:16 PM »
Yes, take them off.
     Kevin
You have seen this right?
http://zukiworld.com/month_080102/feature_hagen_gastanklift.htm
Offline hobgoblin
  • 224
« Reply #8 on: March 24, 2006, 01:39:46 PM »
  Kevin
Those are kinda cool....Or so I think ;) Ok for my tank lift I cut 3" off the brackets near the rear end,And welded 2''x1.5" plates with nuts back on there.Then I completly removed the rear support(rusted) and replaced it with 2" Heavy angle,and used this for the rear mounting points.The white evap chamber is all most touching the body.Here's some pics....The lift Mike H. done is for a 3" body lift so I just made it up as I went...... ;).
Later Tom K.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #9 on: March 24, 2006, 01:41:57 PM »
I see ;)
 kevin
Offline hobgoblin
  • 224
« Reply #10 on: March 24, 2006, 01:48:21 PM »
Kevin,
It worked out easy,might have taken an hour....My way seemed easy,so that's what I did.I still used the stock skid and didn't have to change anything...OK I take that back...Had to bend the lines on the pass side of tank up so they could be hooked up and clear the frame ;)
Later Tom K.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #11 on: March 24, 2006, 04:21:04 PM »
I like the clean look...
One of the first things I did was take the "Geo" and "Tracker" graphics off my truck...  ...and NOT just because they were PINK...
« Last Edit: March 24, 2006, 04:23:34 PM by jzap »
Jim Z.
96 Tracker
66 Apache camper
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #12 on: March 24, 2006, 07:08:47 PM »
I think it looks great without the factory bumpers. The pinstriping is fine either way, but it would definitley look the best covered in mud!
Jim
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
« Reply #13 on: March 24, 2006, 07:11:39 PM »
Me Too!
If I Can't Weld It          It Can't Be Welded
