my two cents on lifts and sas
  • 35 Replies
  • 8090 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: May 23, 2004, 04:45:44 PM »
I have wheeled my sunrunner for a yer almost, some pretty hardcore stuff.  I have a 4inch body lift, 33x12.5 tires on 10 inch rims and AUTO locking hubs.  yes. everything else is stock
If you're breaking parts, you're driving too rough. Ease off the rough starting, especially in 4low, with big tires. Most things break when people dump the clutch too fast.  Always feather the clutch till you can feel the driveline slack being taken up, then give her heck.
Suzuki has spent countless hours and $$ developing the ifs on our little trucks, believe me it is set up get the most life expectancy and  offroading ability it can give.  Sure calamini gives you a kit that will give you 3 inches of suspension lift, but at the cost of having severe driveline angles.  I dont know the exact figures, but for every 10 degree angle on the cv joint, the  life expectancy is cut in half.  roughly...  Also, how much power it can transmit  is affected.
I like straight axle front ends, they can sure take a beating.  But not on my tractor.  Ifs gives you better ride quality and better contact patch on uneven terrain.   I believe Ifs also weighs less.  The reason Jeeps come with live front end is because it's tried tested and true-  if it works, why change it?  That right there is american thinking.  (another good example is the small block chev - 40 years without a change) If you ever watch a BAJA 1000, look at the suspension- ifs in front, those guys know what works.
Keep her on a diet.   I mean your truck.  Weight is a great advantage, which is why sidekicks are so much better than heeps.   If you are going to carry twice as much weight, you will need twice as much power to do it.  You also need twice as much tire contact area as before.  I saw some pretty awsome tube bumpers done in the past, a guy I know put one on his full size chev that weighed 200 pounds.  no kidding, I almost got a hernia trying to lift it.  All the little extras add up.
Last but not least, http://128.83.80.200/taco/scarysteering.html
check this site frequently, has good points on what not to do, just in case you're feeling creative.
Like I said, just my two cents
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: my two cents on lifts and sas
« Reply #1 on: May 24, 2004, 05:31:44 AM »
Are those Canadian Cents?
;D
« Last Edit: May 24, 2004, 05:31:58 AM by Bobzooki »
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Wildweasel
  • 106
  • Git er Done!
    • Wildweasel's world
« Reply #2 on: May 24, 2004, 07:35:06 AM »
I will only say this, The defintion of Hardcore varies.
what you think it is and others are 2 different things.
Glenn
91 geo tracker, Toyota axles, twin tcases,35's too many mods to list.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #3 on: May 24, 2004, 08:40:03 AM »
takes a jeep with 38s, lockers a heck of a lot more horsepower and several tries to go through the same trails I go through.
TITAN
« Reply #4 on: May 24, 2004, 01:32:33 PM »
yah but a 2 door tackkick on yota axles with 3 inch lifted yj's and missing links would be sick :P
Offline explosivo
  • 3157
« Reply #5 on: May 25, 2004, 06:00:11 AM »
It would be a nice rig, but the point of this thread is that there are advantages to IFS (clearance and weight) over straight axles.
omghi2.us[/url]
Offline Natebert
  • 1098
« Reply #6 on: May 25, 2004, 06:49:57 AM »
They know what works for the Baja...
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #7 on: May 25, 2004, 08:18:19 AM »
I know what works. I miss my tracker but i'm to lead foot and dont have money so i got a sammi..P.S look ;D
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
Offline DaddyDave
  • 204
  • Indeed
« Reply #8 on: May 25, 2004, 08:27:00 AM »
As mentioned previously...apples to oranges.  IFS is great for pre-runner type stuff, baja racing, street driving etc.  But when it comes to rockcrawling, solid axle is the only way to go.  you would be hard-pressed to find an IFS competition rockcrawler i think!
"The maximum effective range of an excuse is 0.0 meters."
  • 6589
« Reply #9 on: May 25, 2004, 09:18:51 AM »
Not too hard pressed. :)
http://www.4wheeloffroad.com/featuredvehicles/131_WEB_WALK/
Offline 1bigtracker
  • 3409
« Reply #10 on: May 25, 2004, 09:48:52 AM »
but what that article failed to say was that he is useing his soild axle rig agian cuz he didn't like that one.  ;)
stu
Offline zookiemike
  • 474
« Reply #11 on: May 25, 2004, 10:14:40 AM »
Good look Eric 8)
Offline DaddyDave
  • 204
  • Indeed
« Reply #12 on: May 25, 2004, 10:45:52 AM »
eric, you almost had a good one there!  ;D  the original solid axle walker evans s-dime is amazing.  had a chance to see it up close and personal at the off-road expo in pomona two years ago.  talk about some serious fab and dough...WOW!
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #13 on: May 25, 2004, 01:49:06 PM »
http://atv.polarisindustries.com/atv/galleryPopup.aspx?ModelID=0CF5A8D4-598D-4CFB-ADDF-AA8817FBF958&PageIndex=0
How many ATV owners do a SAS? IS IT NOT POSSIBLE THAT IFS CAN WORK FOR OFF ROAD USE? It would seem so.
Mike
« Last Edit: May 25, 2004, 01:51:33 PM by Mikerpm4x4 »
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #14 on: May 25, 2004, 01:59:08 PM »
Also, are we talking about profesional rockcrawling here or real world wheeling? I doubt any SAS tracker is going to be more capable than Walker Evans IFS/IRS rig. So again, is it possible to build an IFS rig worthy of trail use? Again It would seem so.
Also has anyone noticed how simmilar an ATV is to a trackick? Coil sprung, Lower control arm, with struts, and cv shafts.  ::)
Mike
