need help
  • 1472 Views
Offline ldodge92
  • 107
need help
« on: September 28, 2012, 11:24:01 AM »
Got question prob a stupid one. just put my first motor(1.6 8v auto) back in. forgot the metal gasket/dust guard that goes between the bell housing and block. is this gonna be a problem?
My new addiction
Re: need help
« Reply #1 on: September 28, 2012, 11:43:28 AM »
Do you mean the guard that goes on the bottom to keep dirt out from getting into the bell housing?
Offline jzap
  • 515
  • How difficult can it be?
Re: need help
« Reply #2 on: September 28, 2012, 07:36:06 PM »
The most likely problems you  may run into are a chewn up starter drive from dirt getting into it as well as starter failure from dirt in the bearings.  You might also get dirt into the rear main seal and open up an oil leak.
Jim Z.
96 Tracker
66 Apache camper
Offline Pest!
  • 52
  • on the road again
Re: need help
« Reply #3 on: September 29, 2012, 11:49:58 AM »
water and mud on your throw out bearing . dirt in the clutch and a wet clutch faster when in deep water.  :-X
88.5 Samurai,1.6L 16V Tracker obdII, Calmini reversal with 5" lift., Bushwackers, Rockrawler wheels w 33" 1050/15 BFG KM2s  ,TC. Bumpers, Lockers,  4.16 Tcase, power steering , oversize fuel tank, Warrior Rack
Bob
Offline WesP
  • 40
Re: need help
« Reply #4 on: September 29, 2012, 08:05:06 PM »
Bite the bullet and put it in. It can be slipped in by sliding the trans back a bit.
Re: need help
« Reply #5 on: September 30, 2012, 09:22:08 AM »
Sounds like he might be talking about the upper spacer, not the lower dust shield.
The spacer also locates/stabilizes the starter.  I would slide the tranny back and install the spacer, if it were me.
