need help blowing fuse
  • 1154 Views
Offline westvilleguy
  • 53
« on: November 11, 2006, 01:57:19 PM »
my 91 tracker recently started blowing fuses not sure what its for its the last fuse on the second row in a 91 tracker and its a 15 amp fuse i'm thinking it may be for the fuel pump as i cant here it kick in. as soon as i turn the key the fuse blows so i must have a bare wire or something but would be a start to know what the fuse is for or if someone might have a diagram of the fuses that would be great so i can go from there on finding the problem checked all the  wires i could see and they all seem in tack
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: need help blowing fuse
« Reply #1 on: November 11, 2006, 03:17:30 PM »
I think thats the Ign fuse. Unplug the O2 sensor and see if the problem stops. Ive seen the O2 heater fail and short out popping the Ign fuse.
Mike
Offline mntracker
  • 314
  • MORNEAU MVP
« Reply #2 on: November 11, 2006, 03:37:56 PM »
I have the fuse box panel which has the fuses on it in my 92, would it be the same? If so, I'll take a look at what its labeled.
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #3 on: November 11, 2006, 06:34:11 PM »
Yes it would be the same
