Need help with P.O.S. starter!! Please??
serioushorsepower
105
May 06, 2008, 02:11:55 PM »
Everytime I take my trackick off road mudding the darn solinoid goes in the starter. I'm on I think, My fifth one by now. Does anyone know what other vehicle starter would interchange with the trackick starter? Or a possible solution to fix the problem I am currently having? It's getting quite expensive to go offroading at this rate. Please let me know. Thanks, Serious.
Nothing but power, Serioushorsepower!!
kingzoo
461
I LOVE MY JLX SIDEKICK
Re: Need help with P.O.S. starter!! Please??
May 06, 2008, 04:19:46 PM »
Do you have problems any other time when using the Zuki?If so I would check for a short,bad relay,or possibly starter.
If not I would try to dertimine which driving conditions are causing the problem.Water.mud,etc.
KING ZOO!!
serioushorsepower
105
May 06, 2008, 04:27:21 PM »
I have no other problems with it until I take it off road. I think it's the mud and water doing it. Is there any way around this problem with these? Possibly a better starter or one from a different vehicle altogether?
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #3 on:
May 07, 2008, 05:16:54 AM »
You should be able clean out the starter, they don't usually get damaged just blocked up. Try sealing up the bellhousing to stop the mud getting in.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
Dazookster
61
Reply #4 on:
May 07, 2008, 03:34:05 PM »
First mud is the hardest on every thing on your rig, bearings, fluids, electrical, cooling, horns (mine was filled with mud from the previous owner). So I would start by water/dust/mud proofing that area and seeing if that doesn't fix the problem.
Wahoo for Global Warming more time to go Wheeling
