Hey Prd2BCdn, how'd you make out with the shifters & stuff?
  • 8 Replies
  • 1451 Views
Offline zaggy
  • 1134
Hey
     How'd the rest of the body lift and modifying the shifters go over the weekend?
Zag
Offline chet
  • 556
  • Zuki time!
Re: Hey Prd2BCdn, how'd you make out with the shifters & stuff?
« Reply #1 on: July 18, 2005, 08:36:24 AM »
I don't know about him but I just finished installing my 3"+3" on the weekend. did the suspension last weekend and the body lift this weekend. What a b*tch! the Body lift was way harder than the suspension!
The shifters are tricky the tcase was not bad but I am going to have to play with the tranny one some more as it hits the dash a bit now and I still need to clearance the rear of the opening some more as it pops out of second when you let off the gas!
I also forgot about the lines from the power steering resevoir and when I jacked the body up the one from the res to the box popped off spewing PS fluid all over the ground  ::)
Offline 1bigtracker
  • 3409
« Reply #2 on: July 18, 2005, 11:43:11 AM »
The body lift is way harder to install then the suspenstion, unless you live on the rust belt ;)
The lines to my PS resevoir got short but never came off,  but i did move it down one hole so the lines had slack.  I don't think there is anything wrong with only having one bolt holding the PS resevoir on as it just holds fluid.
Stu
Proud2BCDN
« Reply #3 on: July 18, 2005, 12:07:33 PM »
I still haven't found anyone that can weld up extensions for me >:(
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
« Reply #4 on: July 18, 2005, 12:35:58 PM »
Any auto body shop should have a welder and be able to stick them back together for you if there are no machine shops around.
Toolman
Offline chet
  • 556
  • Zuki time!
« Reply #5 on: July 18, 2005, 12:51:05 PM »
let me know if you have any questions  :P You could do the lift and do the shifter later as once you put it in 2wd you can leave it there. Maybe drive it to a shop that can do the welding and pop the shifter out there.
You will also need a torch to heat and bend the tranny shifter (unless you have an auto)
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #6 on: July 18, 2005, 09:46:45 PM »
Hey Proud2BCDN,
 If your driving buy I got a mig in the garage, shouldn't be to hard to fix you up
Just  PM me and I'll give ya numbers
Steve ;D
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
Proud2BCDN
« Reply #7 on: July 19, 2005, 11:21:21 AM »
Thanks for the input/offers guys, my neighbor has a mig and is going to weld them up for me :)
Offline zaggy
  • 1134
« Reply #8 on: July 26, 2005, 07:18:22 AM »
Hey Prd2BCdn
     Last I heard you were still sorting shifters and stuff...did you get the lift and shifters done?
How's it working...need some help?
Zag
