Worn out upper link (Calmini 3")
  • 9 Replies
  • 1669 Views
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« on: October 13, 2008, 09:56:01 AM »
My new DD 4-dr has a worn out Hime joint (upper link).  Aslo has egged the braket & worn the bolt.
DOes the Cal Mini lift run a standard hime joint?
Anyone got a part #
              Or should I just redesign it with a larger Johnny Joint ?
Re: Worn out upper link (Calmini 3")
« Reply #1 on: October 13, 2008, 09:58:25 AM »
Redesign!
:D
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #2 on: October 13, 2008, 10:19:07 AM »
Who has the best deal on the RE joint / Johnny joint?
Any brand I should avoid?
My online time is limited right now (wife is sick and in ICU) and been too long since I've fabbed on the buggy.
« Reply #3 on: October 13, 2008, 11:20:18 AM »
Sorry to hear about your wife. try Ballistic Fabrication for joints.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: October 13, 2008, 03:55:44 PM »
Calmini just use a cheap 3/4" heim and they don't last  >:( In the end I went back to a stock a-arm and made a spacer to the diff to suit.
« Reply #5 on: October 13, 2008, 05:00:13 PM »
If you want a JJ, you might as well just buy direct from Currie as everyone is about the same price.  The  bungs are the expensive part, you can get them cheaper from 3rd party manufactures.  Unless you just thread your tube.
Offline pepatt
  • 174
« Reply #6 on: October 13, 2008, 05:30:04 PM »
Is that what you used for the rear links your fabbed?
http://www.zukiworld.com/forum/index.php?topic=23119.msg190224#new
Nice stuff
pepatt
« Reply #7 on: October 14, 2008, 03:39:52 AM »
Yep, that's where I got mine.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #8 on: October 14, 2008, 10:39:54 AM »
Jonny joints have a 2" that is 16x3/4 thread and will thread into the calmini upper arm. I'll try to find a pic.
    Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #9 on: October 14, 2008, 01:34:55 PM »
Here is a pic w/ a 2" jonny joint
