Driver's Door adjustment on 92 4dr sidekick
  • 903 Views
Offline RJkick
  • 634
« on: February 09, 2012, 08:35:01 AM »
Is there any way to adjust the alignment of the driver's door?  When I open it the door goes down about an inch so when I close it I have to use a little more pull to get it back up.  The hinge bolts seemed tight when I tried to retighten them.  Is the hinge pulling away from the vehicle at this point?  Is it common?  Any suggestions on a direction to go in?
My next step is to take the fender off to get a really good look at it.
 Any suggestions are appreciated      Thanks
Offline MongooseVRX
  • 64
    • M.O.S. forum
Re: Driver's Door adjustment on 92 4dr sidekick
« Reply #1 on: February 09, 2012, 09:28:06 AM »
Thats what I had to do to get it back in line.
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
« Reply #2 on: February 10, 2012, 09:28:57 AM »
Mine did this and the bolts were pulling through the sheet metal. we had to weld in some support material and new anchor nuts.
