1.6 won't fit!?!?!
  • 23 Replies
  • 3344 Views
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: 1.6 won't fit!?!?!
« Reply #15 on: November 23, 2007, 06:44:01 AM »
I may be wrong about this.....
...but I believe that the 1.6 engine was not available on the '89 model.
The 1.6 was available in 89 however there was a 1.3 option also. If the engine is FI then it is a 1.6 if it has a carb it is a 1.3
Student of Now Master of Then
87 sammi
« Reply #16 on: November 23, 2007, 09:00:04 AM »
okay so still assuming that i do have the 1.6... any suggestions as to what i did wrong for the motor mounts not to line up?
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
« Reply #17 on: November 23, 2007, 10:30:14 AM »
Are you sure you have the offset on the right side? Right as in correct, not right side of the motor
If its not broken, break it
87 sammi
« Reply #18 on: November 23, 2007, 11:15:42 AM »
ya i checked it twice. the directions call for the offset mount to be put on the passenger side of the motor and that is where it is.
87 sammi
« Reply #19 on: November 24, 2007, 04:16:37 PM »
so the update is that i finally got the motor mounted to the mounts and all but there is still no chance the hood will close. any ideas? i was thinking i may have to make a cowl induction style hood to compensate for the intake for the efi. what ya'll think?
Offline locjaw
  • 2045
  • 22
« Reply #20 on: November 24, 2007, 05:15:43 PM »
when trail ough installed he motor in my sammy they put a 1" body lift under the front 4 body mounts
jason
kingzoo
« Reply #21 on: November 24, 2007, 05:23:01 PM »
   Adding a aftermarket scoop would not be very difficult or expensive,but most people install a body lift to overcome the clearance problem.Especially since it gives more tire clearance and gets the rockers up further from danger.
« Reply #22 on: November 25, 2007, 10:55:58 AM »
I have the same problem with my SJ413, I am going to fit a hood scoop. I don't need the extra tyre clearance and I don't want to raise the C of G just to close the hood.
87 sammi
« Reply #23 on: November 25, 2007, 04:22:27 PM »
ya same here.. i really dont want to do a body lift. and plus, i think the hood scoop will look a lot better!!
