sacle 1 to 10
sacle 1 to 10
sidekick101
128
best site on the net
sacle 1 to 10
January 07, 2007, 01:12:44 PM »
will ti be benifital to adjust the valve lash. car has225,000 km on her. will it save gas or waste o time. 1 low10 get er done hahah
1993 sidekick JX, 2 dr, soft top, automatic,
Jimiweld
234
Re: sacle 1 to 10
January 07, 2007, 02:46:40 PM »
Depends how out of adjustment they are whether or not it will help. If it rattles real loud then I would adjust them right away.
It's an easy thing to do so just do it and see what's going on in there.
1990 Tracker - 3.5" body Lift, 1.5 coil spacers, 31" TRXUS tires, homemade front bumper, Automatic Tansmission, 5.12 diff gears. Rear is Locked
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: sacle 1 to 10
January 08, 2007, 04:50:57 AM »
If they haven't been done for a while I would do them. You tend not to get a rattle on Zuk motors, the gaps close up as the seats wear. If you run with the gaps too small you can burn out an exhaust valve.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
