2" calmini kit proublem???
  • 1286 Views
Offline Jecky4x4
  • 22
  • 4x4 for life
« on: September 17, 2007, 10:47:52 AM »
hi all ,
We instal a 2" calmini kit for sidekick and we have a noes from the front shocks,
need some help for this proublem
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: 2" calmini kit proublem???
« Reply #1 on: September 17, 2007, 11:21:19 AM »
I don't understand the problem. Could you try to explain it any clearer?
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #2 on: September 17, 2007, 12:47:06 PM »
Call Calmini.
Student of Now Master of Then
Offline Digger
  • 1991
« Reply #3 on: September 17, 2007, 04:38:03 PM »
Do you mean the front struts are making a noise? They might be topping out too hard, making a clunking noise on full extension. Were the struts brand new? If so, you should probably call calmini and talk to them, maybe the struts are bad or maybe the kit needs some time to settle...
« Reply #4 on: September 18, 2007, 07:31:05 AM »
Are you are hearing a squeeking/rubbery kind of sound form the front suspension? If so, did you lube the bushings with the supplied grease when you installed them? If not your in for a ploy-bushing squeeky ride.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: September 18, 2007, 12:26:14 PM »
 I think they may be having a run of bad struts. I know someone else who has a deffective strut that was just installed.
Mike
