Rockrat's Transfercase Doubler???
  • 8 Replies
  • 7592 Views
Offline TrakJD
  • 232
« on: September 01, 2007, 01:18:28 AM »
I was looking at Rock4xfabrication.com and found no TC doubler, I heard that he had made a few of them, I am wondering if hes planning on putting it on the market? or???
From what I read......Its a doubler where you use Sidekick/tracker's transfercase and hook it to Samurai's TC......
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: Rockrat's Transfercase Doubler???
« Reply #1 on: September 04, 2007, 05:52:19 PM »
i fabbed my own twin t-case.  stan
Offline Wildweasel
  • 106
  • Git er Done!
    • Wildweasel's world
« Reply #2 on: September 05, 2007, 08:55:12 AM »
Just call him and he will make one up for you. Not sure why he doesn't advertise them.
Glenn
91 geo tracker, Toyota axles, twin tcases,35's too many mods to list.
Offline fullsink18
  • 250
  • Wheel Me!
« Reply #3 on: September 05, 2007, 01:16:48 PM »
Already talked to him after i got back from gonzookin.  He said he is working on a redesign to come out in January.  I want to run the twin stick in my sidekick need the reduce high pretty bad.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #4 on: September 05, 2007, 08:56:58 PM »
How and what did you do?  Did you add a sami case?  Pics?  Thanks
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline 37kicker
  • 319
« Reply #5 on: September 07, 2007, 10:42:22 PM »
started out using 2 kick t-cases, but gear 2 gear was better. so i used a sammi t- case.    stan
Offline TrakJD
  • 232
« Reply #6 on: September 09, 2007, 10:30:18 PM »
Rockrat's design uses Sidekick/tracker's TC and attaches it to a sami Case.
37KICKER, Im sure you use Sami T case, but HOW?  What did you do?  was it different than what Scott at Rock4x Fabrication did?
« Reply #7 on: September 11, 2007, 12:26:43 PM »
I made my own doubler too.  Rockrat basically copied it, with a few changes.
http://bbs.zuwharrie.com/content/topic,46349.0.html
Offline 37kicker
  • 319
« Reply #8 on: September 18, 2007, 05:50:38 PM »
mine is very similar, the shifter is alot different.
« Last Edit: September 18, 2007, 06:43:56 PM by Mikerpm4x4 »
