Questions on 5" calmini lift
  • 1225 Views
Offline Ak Zuke
  • 17
« on: October 17, 2010, 11:26:04 AM »
I have a 86 Samurai that I put a 5" calmini lift on and I am running 31" tires.  I am noticing that the rear suspension has no down ward travel, so it seems.  If I jump on the rear hitch I can compress the springs but when it comes back up it seems it is at its limit and I think the shocks are stopping it.  I am taking it to the shop today to see if there is something wrong I am also going to disconnect the rear shocks to see if the shocks are limiting the movement.  Any help here would be greatly appreciated.  Thanks
Re: Questions on 5" calmini lift
« Reply #1 on: October 17, 2010, 06:53:48 PM »
Springs are still new and stiff. When new,  that system give more that 5".  You need to beat on it, flex the suspension as much as possible, and give it some break in time.
Did you weld in the bumpstops?
Offline DaddyDave
  • 204
  • Indeed
« Reply #2 on: October 18, 2010, 07:24:11 AM »
are you running the shocks inverted?
"The maximum effective range of an excuse is 0.0 meters."
Offline RIKSTR
« Reply #3 on: October 19, 2010, 07:19:51 PM »
Inverted????
Do you have some pics? Might make it easier to spot a problem
