knocking sound after 2"body lift
  • 14 Replies
  • 2812 Views
Offline pdasilva
  • 71
  • Suzuki Rules...
« on: November 12, 2003, 07:08:36 PM »
Hi there..i have just recently installed a rocky road 2'body lift,but for some strange reason when turning left i get this slight knocking sound on the left front side of the vechile.The vechile is a 1994 2 door sidekick.
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
Re: knocking sound after 2"body lift
« Reply #1 on: November 12, 2003, 07:14:34 PM »
have the exhaust mounting rubbers come loose. there are two of them online with the front of the gearbox that keep the exhaust central. if one of these has dropped off it will let the exhaust swing and knock ... trust me .. been there. ;D
Offline pdasilva
  • 71
  • Suzuki Rules...
« Reply #2 on: November 12, 2003, 07:40:51 PM »
Thank you.. ill have a look and let you know...
Offline UberAsuna
  • 239
  • Asuna Sunrunner 92'
    • Cranky's Ghetto My Website
« Reply #3 on: November 12, 2003, 11:56:12 PM »
see since i got my 3" body lift last year i got some masive knocking sound in the back like as if my tailgate is loose or somtin its anoying and i never found a solution for it :(  it cant be my mufler since i got none since last week it ripped off and the noise is still three :\
can yall help me out ??
It's A Zuki Thing, Dig It Sucka ;) :D ;D
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
« Reply #4 on: November 13, 2003, 12:47:51 AM »
if you undo the bolts on the body lift and use some copperslip grease on the top and bottom of the rubber mounts (original) and then retighten the bodylift you will probably find that the noise goes away. i have to do this to mine to stop that happening and the sound is like a knocking coming from the door pillar.. not had the same problem since i did it. i think its just the rubber getting compressed and moving under the weifght of the shell
hope this helps ;)
simon
Offline UberAsuna
  • 239
« Reply #5 on: November 13, 2003, 04:59:36 AM »
Thx simon ill have to try this out ... let see when i got time :\ lol
Offline pdasilva
  • 71
  • Suzuki Rules...
« Reply #6 on: November 13, 2003, 05:42:00 PM »
Hi There ..checked the exhaust mountings,they all ok,the knocking noise is very light and only happens when turning sharp left.
Offline ntjoe
  • 50
« Reply #7 on: November 14, 2003, 01:28:43 AM »
Sounds like your could be hitting a bumpstop if you are doing a hard left.....
Try it when you are parked and turn the wheel the whole way left and see if you get it then.  You might not but I'd bet thats just a bump stop.
Good Luck!
1996 Geo Tracker 4WD
1989 Maxima SE 5 Speed
Offline pdasilva
  • 71
  • Suzuki Rules...
« Reply #8 on: November 23, 2003, 09:31:27 PM »
I have managed too sort out my knocking sound problem..i loosened all the body lift bolts and greased all the rubbers and all the contact surfaces .Thanks for the help...
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
« Reply #9 on: November 24, 2003, 12:30:47 AM »
 ;D
no problem
glad some of the crap i store in my head helped
;D
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #10 on: November 24, 2003, 06:14:24 AM »
Check the clearence where the shifters come thru?  They can hit the body occastionally, especially low speed and under throttle.
Remove the rubber boots so you can see the metal and shifters, then do the left turn.  See if anything hits.  If so, grind a little away.
I had to do this after adding the 2" SkyLift.
HTH,
Yankee Tim
Offline sarmeier
  • 43
  • I love YaBB 1G - SP1!
« Reply #11 on: November 25, 2003, 12:26:55 AM »
Did you have to extend the gear shifter or high/low range shifter?  I'm thinking about doing the RRO 2" body lift also.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #12 on: November 25, 2003, 11:07:40 AM »
I DID BOTH WITH MY 3" BODY LIFT FOR HELPING IT STAY INTO GEAR AND NOT POP OUT ALL THE TIME  ;D  I'D SAY YES YOU DO ..BUT NOT A 100 % SURE ON THAT...
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #13 on: November 25, 2003, 12:35:46 PM »
I didn't have to extend anything for the 2" lift, although I partically cut the tranny shifter, gave it s slight bend and welded it back together.  I had to use a carbide tool and hog away some of the sheet metal, and plat a game of spin the rubber boot retainer to make it all nice-nice.
« Last Edit: November 25, 2003, 12:37:50 PM by Yankee_Tim »
Yankee Tim
« Reply #14 on: November 25, 2003, 12:40:29 PM »
I extended the 4WD shifter 3" for a 4" body lift,
stays in 4WD-L ok for the most part, pops out
a couple of times at first until I've been in for
a while then no problem.
