No go Wild.
  • 11 Replies
  • 2887 Views
Offline Samurai_Hamster
  • 28
  • 87 Octane knocker of a motor.
    • Samurai Hamster
No go Wild.
« on: July 10, 2004, 08:47:20 AM »
Just installed some Autolite 3923 plugs (one heat range colder than OEM) and yanked the NGK plugs.
Three Marlboros and one beer later, the spark knock is still there in all its glory. ??? ??? ???
WTF right? ??? ??? ??? ???
I only have 29 more payments to go before I own it outright so I considered a trade but then thought for a bit.  Between this rig and my Dakota, I've been making car payments since Jan 2000.  And its getting old.  Really old. :-[
So I wil try to hang onto this gerbil and feed it hi test in an effort to keep the spark knock at bay.  Have yet to hear back from the dealer on my trevails.  I plan to call them this week with a reminder of "Hey remember me, the customer?"  See what they say.  I pretty much can guess the answer......run higher octane fuel!  Yea, right!
Hopefully it will last until paid off.  Then I can go from there.
Sigh..........and I'm otta beer now! :'(
« Last Edit: July 10, 2004, 08:47:40 AM by samurai_hamster »
The Zuke is on its way out.  Getting a vehicle that will behave and be supported by the dealer.
Re: No go Wild.
« Reply #1 on: July 10, 2004, 04:27:15 PM »
Best of luck to ya.
Offline idaholwb
  • 772
Re: No go Wild.
« Reply #2 on: July 10, 2004, 05:09:09 PM »
 Hey Hamster, I have a buddy that has been a service advisor with Suzuki for years, I will ask him on Monday about the knock. Hopefully I can get a solution for you.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
Re: No go Wild.
« Reply #3 on: July 10, 2004, 05:48:24 PM »
     Ok, you're probably not going to want to hear this, but me being the glass half full kind of guy I am I have this little bit of knowlage to offer.  I use high test in my 2.0 and I get an average of 27 to 27.5, which is pretty good in my opinion, with the cost of gas these days (believe me I know I work part time in a gas station  ;D)I've learned a few things, believe it or not, on average, it's only about a dollar more for you to fill up with the super stuff.  Maybey this will cheer you up.........Or not...... ;)  Hang in there
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
Offline bandit86
  • 1641
  • elv8rguy
Re: No go Wild.
« Reply #4 on: July 11, 2004, 09:21:44 AM »
retard the timing.  check what it is, go back 5-6 degrees and see how bad the knock is.   Also, have a check at you knock sensor - I dont know where it is or what the specific test is, but that would be my next guess
Re: No go Wild.
« Reply #5 on: July 11, 2004, 12:21:38 PM »
Ya, start at 3* retard, and see if it gets better,
unless there is no dizy then I don't know what else
to   tell you
Offline Agent Orange
  • 711
    • Trying to learn
Re: No go Wild.
« Reply #6 on: July 11, 2004, 12:55:29 PM »
can you adjust the timing on an engine with no distributor, cause i'm sure the vitara's don't have them.
Offline jerryp58
  • 449
Re: No go Wild.
« Reply #7 on: July 11, 2004, 02:06:04 PM »
This is a long shot and maybe even a dumb idea, but could it be a hot spot on one of the cylinders caused by a clog in the water jacket?
If so, your temp might be in spec, but a cylinder might be heating up enough to cause detonation.
If you think it's a possibility, maybe you could get your hands on a temp gun and shoot the block for signs of overheating.
Just a thought.
Jerry
1990 Geo Tracker,  2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
  • 6587
Re: No go Wild.
« Reply #8 on: July 12, 2004, 02:20:30 AM »
Yeah, you can. There is an electronic pickup that is located on the rear of the engine head and is driven off of the cam. It is where a distributor would be if it had one... There is a factory pen mark showing where it was timed at the factory.
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
Re: No go Wild.
« Reply #9 on: July 12, 2004, 08:05:24 AM »
Hamster,
 I really doubt you want to hear my actual opinion, but I'll put it out there for you.  There is a knock sensor and that really sounds like the cause of your problem.
« Last Edit: July 12, 2004, 08:29:04 AM by LawDog »
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
Re: No go Wild.
« Reply #10 on: July 12, 2004, 02:47:34 PM »
Hampster,
       If your truck runs and Idle's just drive it. When something breaks then take it to the dealer!
"I do what I want"
LMS wasted my time
mperry
Re: No go Wild.
« Reply #11 on: July 14, 2004, 01:49:40 PM »
Before you give up, have you pulled the EGR valve? (2 bolts & a < $1 gasket.)
I know yours is a diff engine than my 1.6, but cleaning out the the EGR passages allowed me to run regular. (1st time since it had 20K miles.)
