OBD1 Software
  • 27 Replies
  • 16304 Views
Re: OBD1 Software
« Reply #15 on: July 08, 2009, 08:57:20 AM »
I've now published a schematic for an interface which is guaranteed to be compliant with the Suzuki hardware:
http://www.rhinopower.org/Rhinoview/SDL_IF/SDL_IF.pdf
  • 6593
Re: OBD1 Software
« Reply #16 on: July 08, 2009, 08:59:43 AM »
Link no worky...
Re: OBD1 Software
« Reply #17 on: July 08, 2009, 02:48:13 PM »
Seems to work OK now.
« Last Edit: July 08, 2009, 02:49:58 PM by Rhinoman »
Re: OBD1 Software
« Reply #18 on: July 08, 2009, 04:06:16 PM »
Well...
I bought a USB version of the one from your first link, hopefully that will work also.
Edit - it seems to use an FTDI driver - so I'd say I'm good to go
« Last Edit: July 08, 2009, 05:29:41 PM by fordem »
Re: OBD1 Software
« Reply #19 on: July 20, 2009, 08:47:11 AM »
Rhinoman
I sent you a couple of emails - got no response, but I see you active here - maybe the emails got trapped by your SPAM/junk filters, maybe you responded and that went astray?
Re: OBD1 Software
« Reply #20 on: July 21, 2009, 12:49:03 PM »
Sorry I thought I had that address forwarded. I use RS232 Hex Com Tool to verify the serial link is OK. There is a problem with changing Com Port settings after connecting, this seems to be something to do with the interface to windows, I'm going to try using the FTDI dll instead. I'm still playing with my new interface, the output transistor was too slow so I need to have a rethink. If its an 8V they are usually 15625 baud, 16V may be 7812 baud, ignore the 9600, that was just there for development purposes.
Cheers
James
« Last Edit: July 21, 2009, 12:58:44 PM by Rhinoman »
Re: OBD1 Software
« Reply #21 on: July 21, 2009, 02:06:28 PM »
So you've fixed that and I can re-send the email, or, you have another email address I should use, or ....?
Re: OBD1 Software
« Reply #22 on: July 21, 2009, 02:35:08 PM »
I fixed it and I've got the mail now.
Re: OBD1 Software
« Reply #23 on: July 23, 2009, 04:42:31 AM »
I've got my prototype interface working now, I had the comms inverted so I had to do a little rework.
Re: OBD1 Software
« Reply #24 on: July 23, 2009, 10:38:22 AM »
I've fixed the issue with the ID string, set up the comms, connect and then press Get and that should work OK. I'm going to create a simulation file for the data stuff next and debug that.
Re: OBD1 Software
« Reply #25 on: July 23, 2009, 11:03:26 AM »
New version gives the cannot open file bin/snort.bmp error.
Haven't had the time to go plug stuff back in yet - maybe this evening, I'll let you know what progress when I do.
Re: OBD1 Software
« Reply #26 on: July 23, 2009, 12:18:00 PM »
You only needed to replace the executable. I've updated the zip file now anyway.
Re: OBD1 Software
« Reply #27 on: August 27, 2009, 01:37:27 PM »
I'm working on a bug fix at the moment and a big update to allow the software to show raw data in the dataviewer and graphing function. There a few people involved with this now with a variety of Zuks (mainly Swifts) so I've set up a new forum to allow us all to exchange information more easily .
http://rhinopower.activeboard.com/
This forum is strictly for Suzuki ECU reverse engineering modifications and diagnostic software. If it doesn't start or misfires then please post on one of the regular boards (like this one!).
Eric: If this post is inappropriate then please delete.
