ECM cross referencing?
  • 9 Replies
  • 5499 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: July 19, 2005, 10:09:33 AM »
I am getting a 92 4door kick auto with a 16 valve for parts/engine donor and it's computerless. I just grabbed the computer from a 95 2door auto Tracker with a 16 valve from the pull-it yard. The plugs look the same and my confidence is high that the computer I grabbed works because the tracker was obviously running when it became junk(the front end was smashed). Does anyone know if this computer would work in the 92? The sticker says 33920-70EB across the top and US-3AT across the bottom...
Offline zaggy
  • 1134
Re: ECM cross referencing?
« Reply #1 on: July 19, 2005, 10:11:56 AM »
Yo Digger
     Are both of them 4spd auto........if so you are probly good, if one is a 3spd yoou are probly hooped......
My interchange system shows   92-95 Canadian but adds the cautions above
Zag
Offline mrfuelish
  • 2862
« Reply #2 on: July 19, 2005, 04:29:34 PM »
I would also go back to the yard and see if the 95 is obd2, look for a wire underneath the front of the oil pan, if it is there I would say no unless you get the harness and the oil pump and dist. also. ;D
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #3 on: July 20, 2005, 12:21:18 AM »
It will not fit your 92. 92 2doors have 8 valves which have different computers
mike
« Last Edit: July 20, 2005, 12:23:43 AM by Mikerpm4x4 »
Offline Digger
  • 1991
« Reply #4 on: July 20, 2005, 01:20:53 AM »
mike
Mike, the 92 is a 4door and most definately a 16 valve. The computer came from a 95 2door with a 16 valve, both autos...
Offline zaggy
  • 1134
« Reply #5 on: July 20, 2005, 03:42:16 PM »
Both 3 spd auto's or 4spd auto's?
Zag
Offline mrfuelish
  • 2862
« Reply #6 on: July 20, 2005, 09:26:43 PM »
Hey digger, I looked around the shop and found a ecm with the same numbers as yours and plugged it into my 1993-4 5 speed rig and it ran great,my book says your numbers are for 1994-5 so if your running an auto I would just check to see if the trannys are the same, plug and play.
Offline Digger
  • 1991
« Reply #7 on: July 20, 2005, 10:46:17 PM »
With neither rig running, and one really junked up front, how do I tell if the autos are 3 or 4 speeds?
Offline mrfuelish
  • 2862
« Reply #8 on: July 20, 2005, 11:08:55 PM »
not sure about the autos but the numbers on the ecm  3at  maybe thats for a 3 speed auto tranny?
Offline zaggy
  • 1134
« Reply #9 on: July 21, 2005, 07:07:50 AM »
Darn this small screen....
     Just saw that you had the US-3AT,yes that defines the computer as US spec 3spd automatic.
     The difference between the 3spd and the 4spd is the 4spd has an overdrive, if I remember right it shows as a D with a circlea round it on the PRNDL.
Zag
