OH.....NO!!!  Not another oil consumption thr
  • 27 Replies
  • 5867 Views
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
Re: OH.....NO!!!  Not another oil consumption thr
« Reply #15 on: January 11, 2005, 11:57:40 AM »
Hey Bobzuki, umm just one more thing (in the voice of Columbo)  Did you use 10- 30 the whole time or did you use 5-30, or both?  Thanks again,  Dave ;D
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #16 on: January 12, 2005, 01:09:55 AM »
Used both - 5W30 in cold weather, and 10W30 in warm weather - now, it's 5W30 all the time!!!  Oh, and she's up to 123,000 miles, and still no timing chain sounds!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 435
« Reply #17 on: January 12, 2005, 07:09:44 AM »
Well, that's good.  I guess it's a lot of highway miles huh?  How bad did the noise get before you realized that you had to change the tensioners?  Mine hasn't made the noise for a week now.  And how long do you think it can go with them on their way out?   Thanks,   Dave ;D
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #18 on: January 12, 2005, 08:08:33 AM »
Well, not exactly highway miles...  It's not city miles either - twisty little roads up and down the mountains - HARD driving - about 70 miles a day.
It got pretty noticable, before we did anything about it - and it's not like I think the chain would ever break, or jump a tooth - maybe just get sloppy, and give you some "shift" in your valve timing.  But then I'm not sure.  I'm pretty sure though that the V6 is an interference engine - if you break a chain, you probably WILL put a valve through the top of a piston...
Bob
shilly
« Reply #19 on: January 12, 2005, 08:53:08 AM »
I know we're getting a little off the original, but to answer the first post, I used to have an oil consumption problem (1-1.5 qts/3000 miles) until I switched to the Castrol extended life dino juice. Now I'm down to about .5 to .75 per 3000 miles. I'm convinced it made a difference in my trucklet; anyone else have the same/different results?  In addition, what's the concensus on 10-40 in an engine with 140,000 miles on the original engine?  Average use is 85 miles per day commuting, mostly at highway speeds (55-65 MPH) and a warmer climate (SC).
                                 Thanks,  Bubbazuki
  • 435
« Reply #20 on: January 12, 2005, 10:13:16 AM »
Oh yeah, the original question......  Hey, the timing chain thing got me off my short little attention span ::).  Now, I use regular Castrol and a Purolater oil filter (Never did answer THAT question before either)  Is that a partial synthetic???   Thanks,  Dave
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #21 on: January 12, 2005, 11:35:02 AM »
When i had the swift motor in my samuri the rear main went. I used to drive it till it ticked ,then fill it back up. :P
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
« Reply #22 on: January 12, 2005, 02:38:26 PM »
That's why I had to rebuild my
last engine, and turn the crank
20 under, it ticked and I had none
to put into it   :P
Offline zookiemike
  • 474
« Reply #23 on: January 12, 2005, 03:26:02 PM »
OOP's ;D. It ate a valve .My buddy kyle was like"what are we gonna do" I was like ...."walk" ::).
« Last Edit: January 12, 2005, 03:26:39 PM by zookiemike »
« Reply #24 on: January 12, 2005, 05:50:07 PM »
Thats a little more than an oops
Is that the new PCV system ???
  • 435
« Reply #25 on: January 13, 2005, 02:46:46 AM »
Thats a good answer.  Anybody else use the Castrol we were talking about earlier?
Offline zookiemike
  • 474
« Reply #26 on: January 13, 2005, 05:31:41 AM »
I had VAlvoline in that machine. I'm gonna start running AM'S Oil again ;).
  • 435
« Reply #27 on: January 13, 2005, 09:57:31 AM »
Funny you should mention that.  My Dad bought Valvoline ONCE, back in the early seventies when I was a kid.  He said it ruined the cam in his 73 Chevy Pickup with a 350.  Don't know if it really did or not, but he blamed it on that and never bought it again.  Me neither.  The reason I got Castrol was when I first met my wife about 13 years ago her dad only used it.  They had two Ford Festivas, (remember them??)  Just basic 4 cyl 4 speed (nope, not even a five speed) and that's all he used, sometimes he'd go 6 or7000 miles between oil changes, and those things still ran good..   I was sold, and I've used it ever since, never had a problem really either.   ;D
