ok guy,s
  • 12 Replies
  • 3857 Views
Offline rabidray
  • 46
  • hey what you want!!!!!!!!!!! !!!!
ok guy,s
« on: October 29, 2003, 09:44:00 PM »
how strong are tracker driver side rear axels.....ive been told that they are weak.........
my problem is i need a new hybred axel houseing {crushed axel tube} my solution is cut pass side of a kick axel assy reweld the kick bearing retainer thing and run a zuk short side axel on the pass side and a stock kick axel on the driver side.....ya ya i know it will be about an inch and 3/4 short......but i think that can be worked around with a spacer or a different back spaceing on the on the rim.........
and yes i know there are several vendors out there who make hybreds
{ the correct way} in my best geek voice.....but i want too try it my self.......
with this setup all i have too do is get the length correct and thats it .....the axel tubes should already be true, just lop off the right amount and weld the thingy back on put it all togetherthen center it up to get the tire off the spring pack......then look out!!!!!!!!!!!!!!
88 sammy with a few mods
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: ok guy,s
« Reply #1 on: October 29, 2003, 11:47:36 PM »
I thought Trackicks had equal lenght rear axles. They can be swipswaped I think!?....
Re: ok guy,s
« Reply #2 on: October 29, 2003, 11:53:17 PM »
nope, one side is a little shorter (drivers side is shorter i think)
  • 6587
Re: ok guy,s
« Reply #3 on: October 30, 2003, 12:45:26 AM »
Other than the technical challenge of making this happen you are gaining nothing. The Sidekick axles are whittled down to the same 26 splines as the Samurai and if anything are weaker, in my opinion, because of cheaper metal. For example, I had a Sidekick axle go on the 'Con that looked like a Chic-o-Stix in the middle. Poor heat treat and poor metal to begin with. It was one from a '97 four door, dang near brand new! :)
Good luck, Eric
Offline Natebert
  • 1098
Re: ok guy,s
« Reply #4 on: October 30, 2003, 01:02:49 AM »
Good luck, Eric
Eric,
What axles are you using in your Kick now?  Did you go 27 splines from Spidertrax?
  • 6587
Re: ok guy,s
« Reply #5 on: October 30, 2003, 03:27:50 AM »
Eric,
Howdy Nate,
I'm running late model [5 on 5.5 flange] 26 spline axles still. I have only been easy wheeling and driving the rig back and forth to work. I've been 'kick in it around' with a couple of different vendors. I think most are intersted in 26 spline 4 bolt flange with a better alloy. This would be probably the best seller if it's strong enough. I personally would like to see 27 spline with the 5 bolt flange but this would cause people to have to buy a ARB and go find the larger brakes just to do the swap.
I'm taking the rig down to swap in a 2.7 V6, freshen the body work, paint, and generally clean it up for next season. I hope to have everything done including new stronger axles by January.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: ok guy,s
« Reply #6 on: October 30, 2003, 08:19:35 AM »
2.7 huh? That oughta help keep from twisting those rear axle splines! ;D How about a turbo and nitrous too! ;)  :P
mostly :P
Mike
Re: ok guy,s
« Reply #7 on: October 30, 2003, 09:23:23 AM »
Hey........No trash talkin the Turbo.
I ain't twisten off axle stubs  :P
6:1 T-case gears..Huh you just lookin
to turn 44" Swampers on that Trackick
huh Mike ......... You Rowdy Bad Boy.
;D
« Last Edit: October 30, 2003, 09:24:09 AM by wildgoody »
  • 6587
Re: ok guy,s
« Reply #8 on: October 30, 2003, 11:18:17 AM »
mostly :P
Mike
Hi Mikey!
How you doin? Nitrous is definitely on the list. I'm tired of slow Suzuki... Are you and your gang coming out for Moab?
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
Re: ok guy,s
« Reply #9 on: October 30, 2003, 12:10:55 PM »
Yea were comming to moab. Couple new rides too ;) I dont need nitrous too kick your ass! :o :o :o :o :o :P
Mike
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
Re: ok guy,s
« Reply #10 on: October 30, 2003, 12:13:49 PM »
;D
Im not trash talking, Just jealous. :'(
No 44s. 35s on a Geo is like 44s on most anything else!
Mike
Re: ok guy,s
« Reply #11 on: October 30, 2003, 12:36:09 PM »
I know trash talk ........ That ain't it :-*
But 6:1 .....  I don't know, can you say
going Vertical ............ ;D
When is Moab, Easter Break??? or you
have another one comming sooner???
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
Re: ok guy,s
« Reply #12 on: October 30, 2003, 09:58:25 PM »
Its the week before easter.
Mike
