One more hub question...
  • 7 Replies
  • 1739 Views
« on: July 01, 2008, 08:24:20 PM »
SO My manual locking hubs are fried.  I am leaning towards the Warn hubs but see they are listed several different ways: "External Mount And Flange Mount, Not For Front Axle Disconnect Systems"  Anyone know how to decipher this? Also what is "front axle disconnect systems?"  Thanks!
Re: One more hub question...
« Reply #1 on: July 02, 2008, 05:36:23 AM »
When replacing my 10 year old factory hubs, I went with aftermarket thinking they would be better :-\, but after blowing apart a set of superwinch hubs (no fault of their own, twisted an outter stub shaft in it), I called Hawk and got some good used factory replacements...and never had issues out of them.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #2 on: July 02, 2008, 03:22:02 PM »
...Also what is "front axle disconnect systems?"  Thanks!
The "front axle disconnect system" on my old ?T100 used a vacuum setup to disconnect one side of the front axle to disengage the drive to the front instead of using hubs, as on the older 4x4s and our trackkicks.
I put Warn hubs on my zuke when I got it because the original hubs were shot.  I caught a bit of flack on a couple of these forums, but they have served me well.  The major complaint seems to be that they come loose at inopportune times.  I cleaned out the bolt holes well and used loctite on the bolts.  They haven't loosened yet.
« Reply #3 on: July 03, 2008, 05:24:26 AM »
Thanks guys!  I think I am going to go with the Warns... RRO has the premiums for $124... those exact hubs were $235 at NAPA.  Hawk has some used ones for $75/each but I like the lifetime warranty on the Warns. Reb, thanks for the locktite tip, I will make sure I do that from the get go
Offline RJkick
  • 632
« Reply #4 on: July 03, 2008, 01:06:55 PM »
I have some used originals $40 shipped
« Reply #5 on: July 03, 2008, 04:56:43 PM »
With the Warn hubs, use lock tight and check the bolts before runs.  Without the cone washers they have a habit of working their way loose.
Offline reb
  • 195
« Reply #6 on: July 03, 2008, 08:53:19 PM »
Years ago I had a couple of Scouts.  The Scouts' hubs were similar to Warn (if they weren't Warn) and used a soft washer-type part which, when bent over the mounting bolt head, wouldn't allow the bolt to turn.  I know some Jeeps used the same type of locking device.  I have several that I am thinking about trying, tho they don't seem to fit as well as they should.  Has anyone here had any experience with them?
Offline sklope
  • 135
  • BUSHWACKER
« Reply #7 on: July 05, 2008, 08:09:50 AM »
I bought Mile Marker hubs and have had no problems with them. $110 |removethispart|@ AutoZone 3 years ago.
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
