Opinions on / experiences with Samurai lifts
  • 31 Replies
  • 8769 Views
Offline mrfuelish
  • 2862
Re: Opinions on / experiences with Samurai lifts
« Reply #15 on: April 18, 2005, 04:34:01 PM »
THOSE brackets are no diffrent from the stock ones unless there double walled and are used in spring under to save your u bolts from hitting rocks, Bad pictures.I think petro works sells bolt on front shock brackets, and you can buy shock bolts and weld them on top of your diff to use your stock shocks, if you go lower(weld on mounts) and flip your stock spring plates you will need longer shocks.
« Last Edit: April 18, 2005, 04:38:41 PM by mrfuelish »
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #16 on: April 18, 2005, 04:35:03 PM »
Re-read Cosmo's post at the top carefully.  It has some good advice.
I have my own horror story from Rocky Road Outfitters. I ordered my lifted shackles from them took I think 3 weeks to ship them. They were just tossed in a box no instructions and no hardware I had to make a trip to Home Depot to get hardware was really pissed about the whole thing. I also was not informed when I called them about the shackles that I would need shims to fix the castor angle. Any way enough with my rant.
Do you or anyone know how the bolt on calmini shock mounts / ubolt skidplates work.
Mean Green Wheeling Machine
Offline mrfuelish
  • 2862
« Reply #17 on: April 18, 2005, 04:40:18 PM »
U bolt skids are for stock application. I could send pic's of stuff tomorrow if you need them?pm me your home email add.
Offline mrfuelish
  • 2862
« Reply #18 on: April 18, 2005, 04:46:18 PM »
Oh ya I have three sammies here and one four door, two of the sammies are spoa and one has the calmini lift springs, I just did A whole bunch of work to it I think he must have calmini's web page and a c.c..   put a c.m winch bumper on it with 8k winch, 5'' lift springs ect. ect. ect.
Offline bashzuk
  • 784
« Reply #19 on: April 18, 2005, 05:17:45 PM »
so why do they say the come with the 5 inch spring over lift.
I guess I'm going to have to call them to ask how they work.
Also how much lift am I going to need to run bigger than 33 inch tires.
I have 1 inch already figure the sky lift will give me 4.5 for a total of 5.5 then if I look at getting the bonz eye springs from trail tough that will bring me up to 7.5 inches of lift aproximately.
Course if any one can tell me how much lift with what size tires they are running so that I can get an idea of what size tire I should start looking at that would be great.
« Last Edit: April 18, 2005, 05:24:30 PM by bashzuk »
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #20 on: April 18, 2005, 06:11:36 PM »
There's not much too these mountingplates, just put the one that's on the bottom on top after you grind off the shockmount, bolt the U-bolts back and determine where you want your shockmount to be. I put a piece of angle iron on, welded that to the plate and welded the original shockmount to that.
And I have to say: Had it welded, because I only weld good enough to tack it together to show what I want and have someone else weld it properly ;)
For all different kind of lifts I did on my Sammie, check my website and if you have any questions or want more detailed pics, mail me
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline mrfuelish
  • 2862
« Reply #21 on: April 19, 2005, 10:46:14 AM »
I just put the right side on the left and the left side on the right, no problem. no welding.
Offline bashzuk
  • 784
« Reply #22 on: April 19, 2005, 04:37:49 PM »
Sounds smart to me :D
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« Reply #23 on: April 19, 2005, 05:57:26 PM »
You'll like Sky spring perches. Real serious steel, and they are an easy fit. They slip into your existing perchs, keeping the perch parallel so you don't screw up your steering. This also lets you weld them into your existing perches as well as the axel housing, giving you a stronger mount than the perches that just sit on the housing.
Breeze makes great product too. I've got the breeze cross over steering, works great. Mounts into both the caliper mounting bolts and the king pin. Beefy, tough arm.
87 Samurai
Offline bashzuk
  • 784
« Reply #24 on: April 19, 2005, 06:00:25 PM »
I liked that the sky spring perches were already drilled to move the axle forward 3/4"
I talked to mrfuelish about the kit, how sky's stuff is among other things.
and then I talked to my fiance`about getting it and we are going to get the sky lift kit for my birthday in may.
« Last Edit: April 19, 2005, 06:02:57 PM by bashzuk »
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #25 on: April 19, 2005, 06:17:34 PM »
But it would require re-drilling the U-bolt pattern as the right one is wider, wouldn't it ?
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #26 on: April 20, 2005, 01:02:08 AM »
It would seem like it, huh.
I did the very same thing on one of my super-duper budget lifts. I reused the u-bolt plate and shock mounts by just switching sides.
It works just like that for the rear, switching them.
On the front however, you will need to keep them on the appropriate side. One side is a little bit wider of u-bolts. But what I did is, when you take off the anti-sway bar, keep the bolt that goes into the u-bolt plate. You will use this bolt as you shock mount.
Everything went together just fine after that.
Hope this helps.               Jeff
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
« Reply #27 on: April 20, 2005, 05:03:53 AM »
I've got the Sky Mfg spring pads and driveshaft spacers and I love them (Sky's spring pads were WAY nicer than the rocky road units my friend bought).  I'm using the weld-on lower mounts and doesch tech shocks from trailtough.  Both places shipped quickly and provided quality parts.  I don't like the way sky mounts their OTT steering and dispite previous service issues w/ Rocky-road I got thier kit because I really like thier design.  Much to my surprised, it shipped ASAP and got to me early.  I also lowered the break line mounts on the frame to compensate for the added height/flex.  Everything has worked great so-far but I'm going to get a traction bar for the rear, and soon.
I also am not thrilled about RRO's service.  My advise is that if its an item that they don't make in house (ESPECIALLY T-CASE GEARS!!!!) don't count on the delivery date they give you and keep on them to see if it changes.  Thier gear manufacturer's are extremely unreliable.  To thier credit, I've yet to get a bad part from them.
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« Reply #28 on: April 20, 2005, 08:46:36 AM »
i bought the calmini 5.5 super package lift with the shackle reversal and didnt like the reversal (except for jumping whick after 4 axles in front stopped doing) but i kept the springs and added a spoa, the cool part about the calmini shackel reversal springs is when used without the shackel reversal they kick the front axle foreward 1.5 inches or so, with my 33x14x15 tsl boggers i can climb an allmost vertical wall because from the front of my tires out to the edge of the bumper is abouty 2 inches. it also allowed me to not have to cut or hammer in the wheelwells where your feet are for turning clearance.
http://losangeles.tribe.net/template/pub%2CViewPhoto.vm/context/pcard?page=1&currentoffset=30&parentid=40415b7d-1433-436f-967f-94272d2869f1&sortby=newest&rows=0&r=10025
;D
Offline 6feetofAIR
  • 127
« Reply #29 on: April 20, 2005, 09:00:13 AM »
thought i would add that the rear springs are too weak and sag so i use air shocks to help the back out when i am loaded down with supplies (they also leak if you are hauling ass down a bumpy steep downhill but it lowers your center of gravity in a pinch so i like it that way) but for the front the calmini shackle reversal springs are great and can land fine from 3 feet in the air with the exception of the axle many many times over without loosing their arch or eveness from left to right.
calmini on the other hand, thats another story. those spua skid plate thingies are complete crap and when i bought my kit one had the holes crooked but calmini wouldnt replace it unless i sent it in, they evaluated it and then if they determined it was bad they would send me a new one. the turnaround estimate was 3-4 weeks for this process so i just threw them away and put the stock ones back on. i also bought their 4.5? to 1 gears for the t case and they got chipped up after 100 miles. yes i ahd new bearings and yes i know what i am doing, i am a mechanical engineer and work often in our machine shop so i know their tolerances were sloppy on the set (granted its been a few years since this happened, hopefully they have gotten better) i called them to talk about it and eventually talked to one of their engineers there and he was very defiant that their part could have failed and was a real cock about it so i do not buy anything from them any more, i like trail tough and their service dept, theyre the most friendly people around for sammi parts.
