performing the 1.6 16valves `95 sidekick (how to)
  • 21 Replies
  • 4239 Views
Offline legrandgazou
  • 6
« on: April 25, 2006, 08:02:54 PM »
   Is there some ways to make that 1.6 giving more...I mean "cheap ways"
Offline zaggy
  • 1134
Re: performing the 1.6 16valves `95 sidekick (how to)
« Reply #1 on: April 25, 2006, 09:19:34 PM »
Best bangs for the buck....
1) Make sure it is running right and is well tuned
2) K&N airfilter insert in the stock box
3) 2 1/4" exhaust with a Turbo type muffler from manifold to the bumper
Woke mine right up, snappier, generally more power across the board........side benefit
Gas a solid jump in gas mileage.
Hope that helps
Zag
Online RJkick
  • 632
« Reply #2 on: April 25, 2006, 09:57:05 PM »
I have the tune, 2 inch exhaust, but not the K&N.  Will it still help out?
Offline zaggy
  • 1134
« Reply #3 on: April 26, 2006, 11:29:58 AM »
For sure
The insert lets the engine breath better, bear in mind that the filter by itself will likely not make a difference you can feel but should show up in  gas mileage.
Beyond that basic stuff you start to spend larger money so I hope it works for you.
Zag
Online RJkick
  • 632
« Reply #4 on: April 26, 2006, 01:06:19 PM »
Works for me          especially since gas hit $3.20 today          K&N gets some more cash this weekend
Offline zaggy
  • 1134
« Reply #5 on: April 27, 2006, 12:19:04 PM »
Sorry no sympathy at $3.20
Fuel here is $4.36 per US gallon today
Zag
Online RJkick
  • 632
« Reply #6 on: April 27, 2006, 03:51:49 PM »
ouch
I'm trying to learn how to make biodiesel since there are none in my area
Offline BigPig
  • 276
« Reply #7 on: April 28, 2006, 05:47:53 AM »
Check the timing and add about 5 degrees, as long as it doesn't ping.  :)
'89 Sidekick w/ 4.5" of lift.
« Reply #8 on: April 28, 2006, 08:39:54 AM »
ouch
Look at this page and follow the links if you want to learn
http://journeytoforever.org/biodiesel_aleksnew.html
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: April 28, 2006, 08:40:06 AM »
It costs more, but a header definitely helps, too!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Online RJkick
  • 632
« Reply #10 on: April 28, 2006, 01:59:52 PM »
Great link
the thorley header is on the wish list
Offline Carnage
  • 2453
« Reply #11 on: April 28, 2006, 02:23:20 PM »
whats everyones take on the difference between the insert and the cone filters???
what about 2" exhaust instead of 2 1/4"???
X32...................X32CarDomainPage...................X32
...................RyouBakua|removethispart|@Hotmail.com..................
Help me Heal!!!!!! CLICK HERE!!!!!!!!!!![/color]
Offline zaggy
  • 1134
« Reply #12 on: April 29, 2006, 08:22:36 PM »
Difference between cone and insert is how much you want to spend and what kind of driving you do...
Insert is the least expensive and generically the most practical for off road use.
Cone is great for pavement running and rice rockets but can lead to problems off road, tends to cost a little more too.
2" vs 2 1/4" exhaust
Mathmatically the optimum is the 2 1/4 for the 1.6 8 and 16 valve engines...2 inch will work just fine but if you are doing an exhaust might as well go for what should be the optimum.
Zag
Offline Carnage
  • 2453
« Reply #13 on: April 29, 2006, 08:50:24 PM »
Zag
first off
YOU RULE
those answers are freakin great
(im a little thrown back)
I intend to do my exhaust (very soon)
why is a 2.25 better than a 2, optimally?
what about when split to dual pipe (mathematically?)
this is what I wanted
Header -> CAT -> Muffler -> Duals
(so Im doing research into each one)
Offline zaggy
  • 1134
« Reply #14 on: April 29, 2006, 09:30:24 PM »
If you go to your local library you can get a reference book on Sonic waves and pulses...
In it you can find the formulas to work out the optimum diameter and lenghts of intake and exhaust systems.......then apply it "practically" to different applications.
Sorta like this...
Take the displacement of an engine and the rpm...there is a formula to calculate the volume of the pulse entering the exhaust.
Knowing the size of the port lets you calculate close to the optimum velocity for the exhaust gas.
Working back further you can figure the maximum diameter of the tube to maintain the velocity.
Takes a little work but you can figure out how big you can go without reducing the velocity of the exhaust gas...while creating the minimum backpressure.
Then you back it up by building a few and proving the results...
Best performance best value I have found is a 2 1/4" exhaust with a high quality Turbo type muffler.....if you can afford it get a "Good" header that has ports that match the shape of the exhaust ports. (and a CAT if law requires in your area).
Split exhaust are for looks....doesn't do diddly for the performance...but if it's the look you want go for it.
Zag
