hello
  • 22 Replies
  • 4511 Views
Offline vitara
  • 16
  • I love YaBB 1G - SP1!
Re: hello
« Reply #15 on: May 09, 2004, 04:47:02 AM »
To actually get the body lift does the whole body come off the chassis and then some sort of spacers are inserted? And as per extension for the steering column does did have to be welded?
Re: hello
« Reply #16 on: May 09, 2004, 05:01:54 AM »
Vitara said   "To actually get the body lift does the whole body come off the chassis and then some sort of spacers are inserted? And as per extension for the steering column does did have to be welded?"
Well,kind've. You just unbolt the body and jack it  up enough to put the spacers in. ANd for welding some do and some don't But for the 2"inch Bodylift I would think not.
Offline vitara
  • 16
Re: hello
« Reply #17 on: May 09, 2004, 05:09:54 AM »
I found pics of the calmini setup (3"). How on earth do you insert pics here so that someone can tell me which is the right one?  ;D
Re: hello
« Reply #18 on: May 09, 2004, 05:16:52 AM »
Like this. Right Click on the pic. Click on Propertie. than right click& hold (highlights) on URL address. Right click And copy.
Come back here click on the pic right below -S- (above this) and Right clink between the    img]  here  [/img
Offline vitara
  • 16
Re: hello
« Reply #19 on: May 09, 2004, 06:04:55 AM »
Thx Hotrod cos I also found this and this includes a lot more items. So the one you sent is enough. This is surely of another sort of vehicle.
« Last Edit: May 09, 2004, 06:08:24 AM by vitara »
Offline vitara
  • 16
Re: hello
« Reply #20 on: May 09, 2004, 06:09:21 AM »
Yes sorry that was for an isuzu it seems. I checked again.  ;)
Re: hello
« Reply #21 on: May 09, 2004, 06:55:46 AM »
You scared me. I couldn't figure out what that was for. THought it was a new style ;D Pic posting is easy, once you know how, you just stop at one ;D :D
Offline juggster
  • 119
  • No lowriders here!
Re: hello
« Reply #22 on: May 09, 2004, 11:04:22 AM »
one question laurance, how will you get it here?
if you manage it would be cool, offer the landrover club some real competion :D ever took your vitara to the beach near St. Paul's bay, it is loaded with Land rovers, when i went i got some evil looks, there musta been about 30 defenders there, and i was the only non landrover! hehehe
« Last Edit: May 09, 2004, 11:06:51 AM by juggster »
