please Advice - problem with the transfer in sidekick
  • 2230 Views
Offline hitrick
  • 21
« on: September 17, 2005, 11:08:12 AM »
Dear Friends . I need You advice here .
2day when driving in the sand I  sink   - and when trying to get out - I saw that even though the transfter is on 4X4 LOW\High only the rear wheels are moving ... (I have ARB Rear and Front and they were locked )
the light of 4X4 gone off and the transfer handle was moving only UP and DOWN (LOW-neutral  -  HIGH ) and I can't move it to 4X2 postion .
I checked the front drive-shaft - It didn't move - when I was on LOW (the rear wheel were moving in LOW and HIGH .
I sure the problem is in the transfer . everything is going to it .
It's now night so I can check it - but I guess maybe the base (I don't know the word for it in English) that the transfer and the gear sit on is torn .
PS : it's 97 sidekick with auto lockers - but the problem isn't with the lockers because the front drive shaft doesn't move/turn  at all .
sorry for my poor English - hope You still understand  the problem .
Re: please Advice - problem with the transfer in sidekick
« Reply #1 on: September 17, 2005, 02:51:55 PM »
What other things have you done to your
SideKick? Body Lift, Suspension lift?
It sounds like you were trying to say the transfer
case mount/s were torn or broken, does the case
move about ?
If the mounts are broken and the case moves out
of normal position, the lever might be hitting the
hole in the floor and prevent selecting 2WD
For reference T-case positions are called 2WD (normal)
4WD (next position) neutral (next forward position) and
4WD Low (farthest forward position)
After re-reading your post, I think you might have a
broken shift fork in the T-case, preventing selection
of 4WD and 4WD Low.  This is going to require removal
and dissassembly of the T-case to replace the broken
part
« Last Edit: September 17, 2005, 02:56:51 PM by wildgoody »
« Reply #2 on: September 17, 2005, 02:59:02 PM »
What country are you in? or what is your native
language? We might be able to get some translation
going that would make solving your problem easier
Offline hitrick
  • 21
« Reply #3 on: September 17, 2005, 10:05:41 PM »
move about ?
part
I don't have body-lift , I'm able to select 4WD and 4WD low - the problem is that only the rear wheels are moving - the front drive shaft is like I'n in 4X2 (doesn't turn) .
I can't select 2WD and the 4WD light is off .
till yesterday everything worked fine .
I will check the mount .
10x
Offline hitrick
  • 21
« Reply #4 on: October 05, 2005, 12:38:30 PM »
sorry for the late update .
anyway I removed the transfer upper case and stick - took a big screwdriver - played with the fork inside - and it solved the problem .
thank You for a support I was little hysterical form the idea my transfer was broken from the inside .
in the end it took me 5 min to solve it :-)
cheers
