extra 10 lb-ft on head bolts, '92 tracker 8v ????
  • 1178 Views
Offline eschneider
  • 40
« on: August 12, 2008, 04:53:43 AM »
A former GM/Geo tech advised me when reinstalling the cylinder head to torque the head bolts to spec plus an additional 10 lb-ft.
Can anyone confirm?  The tech is a pee-pee head, but I have to admit he's usually right.
Offline rascott
  • 669
  • 15
Re: extra 10 lb-ft on head bolts, '92 tracker 8v ????
« Reply #1 on: August 12, 2008, 05:58:50 AM »
why is he a "former GM/Geo tech"?
ever get your torque wrench calibrated? i haven't.
usually specs. will list a final torque range, and i will often use the higher as a guide.
over tightening can cause problems. stripped or broken bolts(studs, nuts) are a pain to deal with.
+10 lbs on head bolts probably wouldn't hurt.
mabe.
« Reply #2 on: August 12, 2008, 04:03:46 PM »
It's my understanding consistency is far more important than + / - a few lbs. DON'T use oil (unless manual says to), make sure the passages are cleared of debris & oil by chasing the threads (with a tap) and cleaning out with break-clean & compressed air.
