has any one run larger than 37" tires
  • 1534 Views
Offline mlovetripp0
  • 204
  • do more with less
« on: June 05, 2006, 10:25:29 PM »
going to build up the zuk with full size axls .was wondering what r&p should i use with my 6.4 tcase gears and 5 speed.i rarely use 1st and 2nd mostly 3rd .when my rear stock axl came unglued.i want to go 37" and larger would this be to much of a strain on my motor and clutch?
87 sammi
Re: has any one run larger than 37" tires
« Reply #1 on: June 05, 2006, 10:37:57 PM »
Well Stan was running 39.5 Pit Bulls
and Jake Palmberg was running 44" boggers,
(Sammy) what did you have in mind for tire size?
Offline mlovetripp0
  • 204
  • do more with less
« Reply #2 on: June 05, 2006, 11:05:44 PM »
i felt so little at mudstock i needed more clearence bad ,so figure bigger tires need more gear,and i think my tcase is low enuff .will i need more motor?
87 sammi
« Reply #3 on: June 05, 2006, 11:17:54 PM »
Need is such a poor choice here,
You Can Always Use More Motor  ;D
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #4 on: June 06, 2006, 06:39:24 PM »
I,m running 39.5 pit bulls with 6.50  gears &  a 4 to 1 t-case works great . but the quest for a few more ponies is always there.    stan
Offline 37kicker
  • 319
« Reply #5 on: June 06, 2006, 06:42:11 PM »
oh yea the rock star has 39.5 pit bulls with 5.12 gears 4  2  1 t-case  works great also.
Offline JayN
  • 220
« Reply #6 on: June 06, 2006, 07:43:55 PM »
a buddy of mine has a sami witha  4cyl wrangler motor on propane with 37's. he has a local reduction box in it. think it is about 150:1. just ordered new diff gears and lockers. it is on d44's that have been narowed.
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
