proper oil for 1.8
  • 1607 Views
proper oil for 1.8
« on: March 29, 2010, 10:08:19 PM »
what is the proper oil weight oil for a 96 sidekick sport with 1.8L?
Offline biker
  • 730
  • It's a sickness I tell ya
Re: proper oil for 1.8
« Reply #1 on: March 30, 2010, 06:13:55 AM »
Only use 5w30, cam tensioners will thank you.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #2 on: March 30, 2010, 07:30:16 AM »
thank you.
« Reply #3 on: March 30, 2010, 10:41:51 AM »
The proper oil depends on the climate & temperatures you're operating in the vehicle in.
Based on the owner's manual, 10w30 is the preferred oil, 5w30 is acceptable in temperatures ranging from -30*c to 30*c, 10w30 for temps from -20*c to 30*c and for temperatures exceeding 30*c, 10w40 or 10w50 - take your pick.
I'm in the tropics - we're >30 most days (it's 31.3 in the shade today), I run a 10w40.
Offline biker
  • 730
« Reply #4 on: March 30, 2010, 06:28:10 PM »
The 1.8 and 2.0 are much happier with 5w30 because of tight clearances in the cam chain tensioners.  I just had to replace all the chains, sprockets and tensioners on my 2.0 because the PO used the wrong oil and the tensioners can't pump up properly when the engine is cold. Not a cheap or fun job.
99 Vitara 2wd
10 Gr Vitara
