Proportional Valve Samurai
  • 2020 Views
PhnxCaller
« on: October 02, 2007, 07:59:18 PM »
Does anyone know where I can find a Brake Proprotional Valve for a 87 sammy? Just looked under the truck today and a steady stream of fluid was pouring out of the valve. Its located about half way down the passenger side of the frame and is a little alum. deal. I can't seem to find one anywhere ??? This year has two rear brake lines (info only). Any help or fixes would be great!!!!!
4x4nvcowboy
Re: Proportional Valve Samurai
« Reply #1 on: October 02, 2007, 08:15:56 PM »
spider trax sells one , Also look|removethispart|@ http://www.lowrangeoffroad.com/sambrakes.htm
phloop
« Reply #2 on: October 02, 2007, 09:06:14 PM »
The two valves listed will not work as the one he is looking for a stock valve.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #3 on: October 03, 2007, 05:24:46 PM »
I have one. Make me an offer. I'll go pull it now. The carcass goes to the wrecking yard tomorrow. It says aisin on it and has three lines out of it and one bleeder. I'll p.m you.
-Adam
If all criminals were behind bars, there would be no one left to patrol the streets.
86 Samurai Tin-Top stock with a Harley 44 sidedraft carb
PhnxCaller
« Reply #4 on: October 03, 2007, 06:02:28 PM »
Yeah mine is the stock valve, found one through Rod's samurai salvage, but there has to be another place to find it! Maybe I could modify a single line version off a 88 or newer or from a sidekick/tracker!?!
Offline daddyizzle
  • 728
« Reply #5 on: October 03, 2007, 11:56:12 PM »
mine's from an 88.5 for what it's worth.
-Adam
