3" calmini body lift
  • 12 Replies
  • 2280 Views
big_kountry21
« on: February 11, 2008, 01:03:02 PM »
any body got any tips or tricks for the bodyy lift on a 96 2 dr.
mic
Re: 3" calmini body lift
« Reply #1 on: February 11, 2008, 01:09:26 PM »
Go and spray all the body studs with a GOOD penetrating oil every day for a week before you do it.
big_kountry21
« Reply #2 on: February 11, 2008, 01:12:42 PM »
i checke dem all. they are loose. it says you willl have to cut and weld.. what do you have to cut and weld
ultra-rebel
« Reply #3 on: February 11, 2008, 01:40:42 PM »
Big    I saw in here somewhere a link to a step by step instructions on installing the body lift.
you may have to search for it a bit or these ones are for a 2dr
There are 8 body mounts and 4 frame pads on a Sidekick. Start with 12 pieces of 2X3" box tubing each cut 3" long. start on the drivers side of the truck and remove all the nuts and bolts from the body mounts on that side of the body. On the drivers side, the front brake the line comes through the inner fender then is clipped to the frame before it goes to the caliper. Remove this clip so the line hangs freely from the inner fender to the caliper. Now with a block of wood against the floor pan jack up the body until the body studs clear the frame by about 2" Drill a hole big enough for the body stud to fit through in the top center of the box tube ( the 3" side) and a hole big enough for a 1/2" bolt through the bottom side of the tube. Be sure to use grade 8 bolts through the bottom of the box tube to the frame, don't use any washers under the head of the bolt as you will want to pull the box tube down into the recess formed by the frame pad, do use a flat washer and a lock washer under the nut to be sure it doesn't loosen up. Next re attach the body to the top of the box tube using the original mounting hardware. Be sure to put the bolt thou the bottom hole before you tighten down the body to the box tube as there isn't much clearance between the body stud and the bolt when it is in place. the procedure is a little different for the the mounts at the front and rear bumper but the idea is basically the same. Once that side of the truck is done crawl underneath and unbolt the brake junction block from the frame, you will find it located on the frame close to the starter on the passenger side of the body. Once this is loose jack up the passenger side of the truck and install the box tube in the same way you did the drivers side. once the tubing is installed rebolt the brake junction box to the frame, but put the bolt through the bottom hole in the junction box and into the top hole in the frame. this may take some prying but it will work and will relieve the strain on the brake hoses. Ok now look under the truck, you will see four rubbing pads which use to ride on the frame rails. Two are between the front seats and two are under the luggage area. Take the last four pieces of box tubing and place them on top of the frame so they contact the rubbing pads. now take coat hangers and temporarily lash them to the frame under the rubbing pads so you can drive it to the local welder and have them permanently welded to the top of the frame. You now have a Sidekick with a 2.5" body lift, Congratulations. The last thing you will notice is that the bumpers are now 2.5" to low for the body. The only way to fix this is to get after-market tube bumpers for your truck. Calmini sells front and rear tube bumpers for the sidekick and he also sells an offset bracket to raise the front bumper to the right height. the back bumper is not raise able but looks ok at the stock height.
Good luck and may the Zuk be with you.
If you have any questions or run into a problem with this installation please e-mail David Ulrich at dulrich|removethispart|@redilink.net
Have fun
Rebel
« Reply #4 on: February 12, 2008, 04:40:25 AM »
The Calmini body lift is supplied bare metal, you'll need to paint it or have it plated.
big_kountry21
« Reply #5 on: February 12, 2008, 07:12:44 AM »
i'm a rattle can master.lol thats why the trak is camo.... also i've noticed that the calmini directions aren't very detailed.
MaD.72
« Reply #6 on: February 12, 2008, 08:03:22 AM »
Don't forget is CALMINI!!! :P
big_kountry21
« Reply #7 on: February 12, 2008, 09:48:22 AM »
is calmini bad?
MaD.72
« Reply #8 on: February 12, 2008, 12:34:42 PM »
Not the part, the service
Offline trckdtrak01
  • 17
  • Got Flex?
« Reply #9 on: February 12, 2008, 12:44:04 PM »
Your best bet would be to call Steve at Calmini and ask him. Dont get me wrong these guys here Know there S*** But steves parts, steves directions, hmm Im seeing a patern here  ???
2001 Tracker
Engine: 2.0 Ltr 16 V DOHC
Transmission: Stock
Shoes: 205/70/15 Goodyear Assurance on 8" uniques
Audio: Pioneer 3wy 6x9's/stock fronts Interior Stock
« Reply #10 on: February 13, 2008, 04:59:15 AM »
There are a couple of rubber isolators on the frame that aren't mounts. The kit comes with blocks to fit between them and the frame once its lifted. These blocks are meant to be welded in place. Also you will have to extend the gear levers, these will also require welding. To fit the bumper raising brackets you need to do a bit of cutting of the bumper metalwork.
big_kountry21
« Reply #11 on: February 13, 2008, 09:03:20 AM »
thanks guys as usual ya'll are helpful
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #12 on: February 14, 2008, 08:49:44 AM »
If you can fab a little, it's not hard to raise the bumpers.  I'll look for pictures of mine.
96 Tracker
32 MTR's Warn 8000i
