Rag Joint Replacement
  • 1849 Views
nitro884
« on: August 28, 2007, 12:02:00 PM »
I'am looking for a rag joint replacement.I want to go with one that use a u-joint.Does anyone know how make a good one?
Offline whateverworks
  • 110
Re: Rag Joint Replacement
« Reply #1 on: August 29, 2007, 08:37:10 AM »
Sammi or Track/Kick?
As for putting in a u-joint... Ya sure it will work just fine. Just that you will get alot of vibration in the steering wheel... If ya don't mind the vibes yer good to go...
Kelly
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #2 on: August 29, 2007, 11:55:11 AM »
If you can fabricate or weld you can use a ujoint from the tracker/sidekick steering shafts.
If not and you want to play it safe then order one.
http://www.lowrangeoffroad.com/samsteering.htm
scroll down and you will see the eliminator.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
