Rear ball joint drop
  • 65 Replies
  • 11360 Views
Offline SnoFalls
  • 1358
Re: Rear ball joint drop
« Reply #15 on: January 17, 2005, 11:52:10 AM »
Mass production is hard, since this one is all machined. All the parts are machined to get an exact fit, then he sets them in a jig to get an exact fit, everything lined up perfect, etc. The machine work is $40/hr, plus the material, etc, etc, etc.
I can see if he can make up a few and see if a discount can be worked. I'll talk to him this week, and I'll see what he can work out.
I guess I didn't see the "machining" ... thought it was; cut some plates, drill some holes (accurately), weld up some spacer plates. I do understand the need for thick material ...
So, the work involved is making the plate (2 for each unit), and then welding in the necessary spacer plates (4 per unit). Spacers could be 2" or 3" ...
Group buy? ... put me down for one (2"). Hopefully others will chime in ...
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #16 on: January 17, 2005, 11:55:44 AM »
Well, I will talk to my dude, and see what he can work up for a group buy. I'll post up here in a few days with what I find.
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #17 on: January 17, 2005, 12:51:12 PM »
Count me in for one (1) 2".  Thanks!   8)
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
« Reply #18 on: January 17, 2005, 03:48:25 PM »
On a mass production scale, I
can have the holes punched,
fast and accurate,  Make this
a group buy and I can see what
a bunch would cost to fab up.
There is a template  that has
been posted here, but I don't
remember who posted it....
« Reply #19 on: January 18, 2005, 11:46:16 AM »
"O" Heck.
I'll d take one ;D
They looked pretty good.
I may use it
or not.
Offline Chief
  • 678
« Reply #20 on: January 18, 2005, 08:59:29 PM »
If you can do this, go for it! I talked to my buddy and he is really backed up w/ work til at least April!!  :o
Offline chrisvitarasport94
  • 228
« Reply #22 on: January 22, 2005, 01:50:27 AM »
I want one please - I've got a guy who said he do the 2" one as per the Brazilian guys spacer, but no progress to date. I would like the simple solid block drilled at 4 corners & a centre hole as per the previous post, as with only a 2" lift is it really necessary to build in any rotation to the diff??
On the subject of diffs, anyone got an axle mounted skid plate ( rather than a diff cage) to protect it?
'94 3dr s/top Sport, roof bars, roof lights, Calmini bumper, SuperwinchEP9, CB & handheld, GPS, 2" body lift, skid plates, 2.5" susp lift, & hi-lift. Safari Snorkel. R Lockright
Offline mineisbroke
  • 134
  • yip
« Reply #23 on: January 22, 2005, 02:09:16 AM »
I would take one but I do NOT want the pinion offset . If  the pinion is turned upward you MUST use a constant velocity joint in the driveshaft . Also pinion angle IS directly related to traction . ( I drag race also ) You would not believe the difference pinion angle makes in traction .
Offline Chief
  • 678
« Reply #24 on: January 22, 2005, 02:24:23 AM »
all this talk of pinion angle......I had a vib after I lifetd about 2", and after I did the spacer w/ the offest, no vib.
« Last Edit: January 22, 2005, 02:25:08 AM by Chief »
Offline 1bigtracker
  • 3409
« Reply #25 on: January 22, 2005, 02:34:17 AM »
i think Whitfeild posted it.
stu
« Last Edit: January 22, 2005, 02:34:50 AM by 1bigtracker »
Offline SnoFalls
  • 1358
« Reply #26 on: January 22, 2005, 12:32:36 PM »
Getting under today to do my third swap, I inspected the pinion and tranny angles ... I agree that a pinion angle change is not needed (or desired). The trans and stock pinion angles appear equal which is the deired setup. They need to be parallel, and I see no no reason why dropping the pivot shoud change that.
Offline 90Stomper
  • 427
« Reply #27 on: January 22, 2005, 01:09:02 PM »
is this really needed?  i have a 2.5" body & a 3" sus lift and have never noticed anything wrong.  have i just gotten lucky?  convince me that i need one and i will be in. ;)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline 90Stomper
  • 427
« Reply #28 on: January 22, 2005, 01:09:16 PM »
Offline 90Stomper
  • 427
« Reply #29 on: January 22, 2005, 01:09:50 PM »
