the RRO "deluxe SPOA 5" lift"
  • 1700 Views
Offline AMCKB
  • I love YaBB 1G - SP1!
« on: May 09, 2005, 05:43:56 AM »
I plan on ordering the RRO "deluxe SPOA 5" lift" along with the ott steering upgrade, Doetsch Tech 3000 shocks, and driveshaft extensions. I was thinking of adding 1 add-a-leaf to each side also. What do yall think am I going the right way on this? How big of ds extensions am I going to need? OKAY LET ME HAVE IT!!!
I forgot to add its a 1987 Samurai!
Offline cosmo
  • 37
Re: the RRO "deluxe SPOA 5" lift"
« Reply #1 on: May 09, 2005, 02:41:16 PM »
Don't hold your breath waiting for it to get to you......RR is known for wasting lot's of time getting stuff out the door.
I won't even start on my experience with them.....it was AWFUL!!!!!!
Why not add a little longer shackle instead of adding a leaf? It will ride better and will be easier too.....
I have the same lift with the 1" lift shackles and it is a pretty good setup....6" of lift overall......fits 31's perfectly.....I even had 33's stuffed on it for a while....but they were too heavy and robbed too much power. Had to do fender tweaking to fit the 33's too...
« Last Edit: May 09, 2005, 02:44:45 PM by cosmo »
88.5' Samurai
Offline rkteckt
  • 214
« Reply #2 on: May 09, 2005, 02:49:39 PM »
I had a luke warm experience with RRO also, but they do come thru in the end.  My front Bull Bar is solid and looks good in a classic sense. It was easy to install, and is plenty tough.
Im thinking about the Calmini 5.5" shackle reverse kit to replace my spoa though.  My lift was done by a rebuilder that i bought trogdor from,  and he didnt do such a hot job.  WIth spoa and stock springs theres almost no flex in the suspension, and on road ride quality is high and wiggly. I'de love to get back to a spring under axel with better leaf springs.
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
GRVIT
« Reply #3 on: May 10, 2005, 06:31:30 AM »
Why dont you all try the YJ spoa set up......???   ride quality and great articulation .
Offline AMCKB
« Reply #4 on: May 10, 2005, 06:57:43 AM »
Okay after doing alittle more research and asking the same question on some other sites I've came up w/ alittle more to it (i think its called the4wd bug)
rr 5"spoa
rr ott steering
rr dt prerunner shocks
north coast off-road R.U.F./CJ springs
north coast off-road A.R.S./ CJ springs
TT front missing link kit
TT rear missing link kit
TT 2" extended Slip yoke
Anyone see any flaws with this other then the cost?
