Removing Stock Bumpers [ TRACKICK ]
  • 13 Replies
  • 4331 Views
Jayzuki
« on: May 24, 2006, 04:09:39 PM »
Hello. I am wondering what is involved in removing the front and back factory bumpers on the Trackick, also how difficult it is. I am guessing that once you remove them the machine is still drivable?
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Removing Stock Bumpers [ TRACKICK ]
« Reply #1 on: May 24, 2006, 04:51:05 PM »
4-6 bolts for the front and a few more for the back.  Takes about 45 seconds each with an air tool.
Yes, you can drive without them, but be careful as you're really exposing yourself at that point.
1993 4-door Sidekick
4.24:1 t-case
Offline Yoak
  • 577
« Reply #2 on: May 24, 2006, 05:01:22 PM »
Crikeymike is right,
its really easy to do, I had a buddy with me to hold it as thing started to get loose. I used basic hand toolds, there are a few bolts as I remember under the platic that took a minute to find, but were easy to remove
Jayzuki
« Reply #3 on: May 24, 2006, 05:28:13 PM »
I am happy its not a long task.
« Last Edit: May 24, 2006, 08:17:21 PM by Jayzuki »
Jayzuki
« Reply #4 on: August 27, 2006, 02:02:38 AM »
Do you have to remove the entire bumper or can you just take the bumber covers off?
Offline Jeff@TireBalls
  • 559
« Reply #5 on: August 27, 2006, 08:31:00 AM »
You can just remove the covers to expose the bumper if you wish.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Jayzuki
« Reply #6 on: August 27, 2006, 09:54:59 AM »
So I guess it would look similar to the Jeep YJ that has no covers? I think it would be neat and you could keep the machine cleaner and better prevent rust. Is it common to find the bumpers rusting after removing them?
How long to remove just the covers [ front and rear ] ?
« Last Edit: August 27, 2006, 09:59:42 AM by Jayzuki »
Offline westvilleguy
  • 53
« Reply #7 on: August 27, 2006, 10:06:11 AM »
only took me a couple minutes to remove my front and back bumper covers couple bolts and they are off
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Jayzuki
« Reply #8 on: August 27, 2006, 10:25:52 AM »
Thats not bad at all!
  • 559
« Reply #9 on: August 27, 2006, 03:43:44 PM »
It won't look as good as a Wrangler, but it will help with offroad approach and departure angles.
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #10 on: August 27, 2006, 04:13:18 PM »
mine had one sheet metal screw holding the drivers side on and one bolt on the passenger side.  took all of two minutes once we figured out that's all there was.   :o
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline RJkick
  • 634
« Reply #11 on: August 28, 2006, 11:28:09 AM »
With the front skin removed would it be strong enough to flat tow from?
Offline bzzr2
  • 1011
« Reply #12 on: August 28, 2006, 12:25:50 PM »
i removed my covers and painted them with hippo liner to make it look like they were supposed to be that way, looks alright.  takes little time to pull covers off.  when i'm finished this weeks little project i'll post a couple pics.
09 taco reg cab short box 4x4
Offline crikeymike
  • 713
« Reply #13 on: August 29, 2006, 02:02:35 PM »
no, you couldn't tow from the stock front bumper.  it uses very small bolts for mounting, and it's just stamped steel, not very strong
4.24:1 t-case
