Removing underdoor panels...
thedeep
50
I Love ZUKIWORLD!
September 01, 2005, 07:45:11 AM »
A friend said he saw an article/video online walking through the process of removing the plastic underdoor panels and replacing them with something else. Anyone know where I can find that? Gotta get rid of these things. Thanks.
Uncivilized
1469
Re: Removing underdoor panels...
September 01, 2005, 09:13:52 AM »
Do you mean the plastic rockerpanel covers?
thedeep
50
I Love ZUKIWORLD!
September 01, 2005, 09:29:46 AM »
Yep. Those evil little bas***ds that collect rust. I've got the plastic off, but what to do with the brackets? I think, maybe, I'll go with a set of diamond plate covers, but I assume one removes the brackets first.
chet
556
Zuki time!
Reply #3 on:
September 01, 2005, 11:05:31 AM »
you can use a spot weld drill to get them off or grind the heads of the spot welds down. Just be careful not to grind into the rocker itself.
You can then paint the rocker with rocker guard or paint it body color. For protection I would mount a bar under the rocker or cut the rocker out and replace it with a square tube.
dsumers
72
Reply #4 on:
September 01, 2005, 10:44:07 PM »
square tube? That sounds interesting.. Have any pictures? What size square tube?
ack
1659
34
Professional askhole
Reply #5 on:
September 02, 2005, 03:25:38 AM »
Try:
http://www.izook.com/tech/samurai/body/ncorockers/ncorockers.htm
in Izook.com's tech section.
It's an illustrated tutorial for installing replacement Calmini diamondplate rockerpanels that shows how to remove the underlying metal brackets.
Ack
Ack's FAQ
http://www.acksfaq.com
lil_Truck
1148
Eric Gardner
Reply #6 on:
September 02, 2005, 05:31:32 AM »
Do you have a Sami or Trakick?
The article is for a Sami.
Some where on this sight rocker gards were discussed (for a Trackick). Someone cut cut out the rockers and replaced them with square tubing welded to where the rockers used to be. Turned out quite well.
96 Tracker
32 MTR's Warn 8000i
lil_Truck
1148
Eric Gardner
Reply #7 on:
September 02, 2005, 05:39:10 AM »
I found a couple nice threads, but don't know how to post them?
Go up to the "search button" and type in "rocker gards" and they will come up.
96 Tracker
32 MTR's Warn 8000i
