Ring & Pinion sizes??
  • 12 Replies
  • 4578 Views
95XL7
« on: June 12, 2004, 09:27:12 AM »
Are Samurai and Sidekick ring&pinions the same size?? Just wondering because i see a place that sells 5.38 ratio gears and that would be perfect for my rig.
Offline Charlie
  • 77
  • I love YaBB 1G - SP1!
Re: Ring & Pinion sizes??
« Reply #1 on: June 12, 2004, 12:03:12 PM »
Those gears fit the front but the rears different, it's next to impossible to find to find those ratios for the rear.
Charlie
« Last Edit: June 12, 2004, 12:03:32 PM by Charlie »
Offline idaholwb
  • 772
« Reply #2 on: June 12, 2004, 04:48:51 PM »
 Front and rear sammy and front kick and GV front are all a 6.925" ring gear. The rear of a kick and GV, not XL-7, are a 7.5" ring gear. From what I understand, the XL-7 uses an 8" or larger rear pinion gear.
Does that help everyones questions? If you need it, I can give all the gear options for all of the above.....?
Sammy........3.73 or 3.90(lwb and pickup)
Kick.............4.30, 4.62, 5.12, 5.38, and the rare 5.62(89 only, 1.3 kick 2 door, only)
GV...............4.10 and 4.88
XL-7............5.12, not sure about other ratios.
How's that? ;D
97 Sport
265/70-16s
2" lift
2.0 swap
TITAN
« Reply #3 on: June 12, 2004, 04:56:26 PM »
your just the gear exoert now arent ya idaho? lol no insult just laughing at my ridelin inspired joke...
95XL7
« Reply #4 on: June 12, 2004, 05:37:48 PM »
How's that? ;D
So what years and model kicks came with 5.38's??
I seen some on carpart.com from a 90 or 91 4 door that said they were 5.38's but i thought it might be a typo.
I will definitly be looking for those gears now.
Offline jagular7
  • 1026
  • Jagular7
« Reply #5 on: June 13, 2004, 03:31:34 PM »
How's that? ;D
Other ratio for -7's is the 4.30 (for the 5-sp).
Lenexa, KS
Offline Gear
  • 112
    • Pics and my club website
« Reply #6 on: June 13, 2004, 08:51:39 PM »
to add to this, i just pulled apart my rear diff in a 2003 Manual GV the crown wheel is 8.5"  and i'm sure the diff ratios are 4.3's
Jeffrey
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
« Reply #7 on: June 13, 2004, 10:47:26 PM »
There were a limited number of 89 Kicks that came out with the 1.3L motor. That is where you will find the 5.38's
Offline blacknight
  • 987
    • Gonzookin
« Reply #8 on: June 14, 2004, 05:40:49 AM »
Jeffrey
Is it 10 bolts??? Also could you take some pics.
George
Offline jagular7
  • 1026
  • Jagular7
« Reply #9 on: June 14, 2004, 07:07:21 AM »
George
George, I have a spare drop out center section with the 5.13's for the rear of a '7. Let me know what info you need?
Lenexa, KS
Offline blacknight
  • 987
    • Gonzookin
« Reply #10 on: June 14, 2004, 11:50:11 AM »
Trying to find out if its the same as a GM 8.5 10 bolt.  If so you could get a locker, arb's ect.....
George
95XL7
« Reply #11 on: June 17, 2004, 10:49:51 AM »
I checked with carpart.com and all i can find in 5.38 is the front? What did they use in the rear? Also see the 1.3lts are 5.63 not 5.38
http://www.car-part.com/
« Reply #12 on: June 17, 2004, 12:20:12 PM »
Idaho LWB forgot the 5.83 Calmini gear
that is available for the kick front and rear
